Magnaflow-Does this sound right??????
Old Apr 21, 2008 | 09:27 AM
dhypnotized's Avatar
Default Magnaflow-Does this sound right??????
Ok guys,I put a new exhaust on my Audi A4 2.8Quattro....
Item:
Magnaflow 2" Hi Flow Univ Catalytic Converter X2
Item:
Magnaflow Muffler 5X8 Oval Street Series w/ TIPS 14816
Getting a BUZZZZZZ sound around 2500-3000 RPM
I have had it checked for leaks multiple times and there are none.
Is this the way this setup is suppose to sound?????????
Old Apr 21, 2008 | 12:21 PM
Bendet's Avatar
Default RE: Magnaflow-Does this sound right??????
I don't think so. Is your setup custom? I had an exhaust once that was installed and it hung a little too low causing a vibration, I took it back they moved one of the hangers up a bit and that fixed it. On another note, if your cat core has broken up, that would also cause a rattle too, but i'm guess that yours is new and probably not the problem.
Old Apr 21, 2008 | 03:29 PM
Do you think it could be because of the high flow Cats VS the stock Cats?
Old Apr 21, 2008 | 03:40 PM
CIA's Avatar
CIA
nop its has nothing to do with stock vs afermarket Cat.
vibration somewhere on your exhaust line is causing the BZZZZZ or you will need a glasspack
Old Apr 21, 2008 | 04:20 PM
01AudiA4's Avatar
Yup i have a bzzzzzzzzzzzzzzzzzzz around that too---I also have a little exhuast leak pre cat though.
Old Apr 21, 2008 | 06:47 PM
klum00's Avatar
by a "buzz sound" you mean something other than the exhaust tone itself right? I know my magnaflow was fairly loud between 2000 and 3000 rpms.
Old Apr 21, 2008 | 09:37 PM
coleA4's Avatar
i just got my exhaust done too and right around 3k rpm i have a noise its more of a rattle but its only when i put my pedal to the floor i think for me its just because i still have the stock muffler and there are restrictions
Old Apr 22, 2008 | 12:30 AM
a4b5guy's Avatar
I removed my stock resinator and muffler, replaced it with a highflow resignator and a magnaflow exhaust. Sounds super sweet in all ranges. Although I do have a small exhaust leak before the cats where that stupid flex pipeing is. Im going to get that fixed as soon as I get back from my vaccation. Thinking about removing the cats and putting something else in, not sure if im going to go hi flow cats/testpipes/or glass packs. What are your opinions? Dont want it really louder just a bit more crisp.
Old Apr 22, 2008 | 01:25 AM
CoBra03TerminAtoR's Avatar
^^ nice avatar lol i got a good laugh out of it!!!
Old Apr 22, 2008 | 01:56 AM
SAudi's Avatar
its gotta be the cats, my buzz like a ******. but i also have a loose heatshield on top of the resonator. let us know if you find a fix, i can live with the rattle but its annoying.
