maintenance question...
Old Feb 20, 2008 | 04:36 PM
tab667's Avatar
Default maintenance question...
hey guys i have an audi a4 1.8T stick. i got around 90k on it and i got some questions about maintenance, first of all thanks for your time. ok so i think i need to change the timing belt because the mechanic told me that supposed to be done at 60k, so is there anyway i can check if the timing belt was changed he said that its gonna cost 800$ to change it. the second thing is that is that when i turn the car squeeks its not so bad, just enoying, friend told me if i have enough power sterring liquid, but it is between the max and low so i guess there is some other problem. oh and the last thing if i would want to sell the car, what kinda price i should be asking for.
Old Feb 20, 2008 | 04:37 PM
tab667's Avatar
Default RE: maintenance question...
oh by the way the car is a 98.
Old Feb 20, 2008 | 04:54 PM
auditech79's Avatar
The timing belt should be done around 80-90k, make sure he quoted you for the tensioners and rollers because $800 is a damn good price. Your water pump is seperate from the timing belt but i would consider having that done as well since he's in there.
If your looking to sell it would be worth around 7K, 9K if the timing belt and water pump is done.
Old Feb 20, 2008 | 06:10 PM
tab667's Avatar
how many more miles you think i can make if i change that, and you think that selling a car after 100k would be a problem? thanks
Old Feb 20, 2008 | 09:07 PM
Trey25's Avatar
Selling a 1.8T 5speed with little over 100k shouldn't be a problem. It's a huge plus if the car is in good shape aesthetically, and the major maintenance stuff like the timing belt are done.
Old Feb 20, 2008 | 09:26 PM
tab667's Avatar
ok thanks guys, but what might be the problem with the car when im turning, its squeeking a little...
Old Feb 21, 2008 | 10:10 AM
turbo kraut's Avatar
Tech Guru
that could be your serp belt
Old Feb 21, 2008 | 11:29 AM
99A4NOW's Avatar
Control arm (ball-joint) most likely.
yellow_submarine
Jan 16, 2011 05:17 PM
Mfillhart#12
Sep 18, 2010 12:49 PM
SeanB
Mar 11, 2010 07:57 PM
secgeek
Jan 23, 2007 03:50 PM
ueberbill
Oct 24, 2005 05:41 PM
