Manual tranny and diff change
Old Sep 29, 2009 | 09:35 AM
schernov's Avatar
Default Manual tranny and diff change
Guys, just to confirm the capacities and procedure:
2001 1.8 Q .
Manual tranny: Fluid Redline MT90 (75w90 GL4) will need 2.75L or 2.91 Quarts.
Fill line is 7mm BELOW the bottom of the fill plug bottom edge.
Drain: 25NM
Fill: 25NM
Diff: Fluid: 75w90 GL5. will need 1.9L (2.1Q)
Fill till drips out of fill plug.
Torque:
Drain:35NM
Fill: 35 NM
Thanks!!!
Old Sep 29, 2009 | 10:41 AM
bbboy's Avatar
Member
Sounds OK, I had it done by a shop (no famous VW drain-plug tool) so not sure about fill levels. I also put MT-90 in the gearbox/trans. case (they share the fluid and that's why it has to be GL-4) and RoyalPurple MaxGear in diff. I remember buyin 3 bottles of MT-90 and 2 bottles of RP MG 75W90
Old Sep 29, 2009 | 03:34 PM
ghost6303's Avatar
i never heard of the "fill 7mm below the hole" thing. i just filled mine up till it started coming out. i dont think that is terribly important. the quantities are correct though. make sure you buy the drain plug tool, and always remove the fill plug before the drain plug. if you cant get the fill plug off dont drain the fluid out, you have no way of replacing it.
Old Sep 30, 2009 | 09:00 AM
schernov's Avatar
It is mentioned on page 37 of maintenance description of work of the FSM....and says not to overfill beyond that mark... I saw it on another audi forum...
Old Sep 30, 2009 | 09:05 AM
ghost6303's Avatar
i didnt say you were incorrect, i just said i dont think that is terribly important to be exactly 7mm below. good luck.
Old Oct 1, 2009 | 09:36 AM
schernov's Avatar
I know...I am just passing along the informaiton.
Donman19
Jul 4, 2011 04:14 AM
BretSV
Jul 11, 2009 03:35 PM
Lefty
Apr 25, 2008 03:27 PM
AG A6
Sep 14, 2007 06:13 PM
ecksman
Apr 7, 2005 10:36 PM
