Master Cylinder install...Need help
Old Nov 2, 2016 | 11:57 AM
johnnycf26's Avatar
Default Master Cylinder install...Need help
Ok, This master cylinder install has been a real pain. I cant seem to get the hard line that goes through the firewall to sit all the way into the new master cylinder. I really dont want to remove the ECU or brake booster to get to the part, but I cant get the thing to line up and slide in correctly. (I'm talking about the hard line that goes from the master to the slave)
Does anyone have a picture of what that line looks like installed? I'm trying to figure out how far I need to go. It seems that there is a compression fitting on the line that should go into the master cylinder, but I cant get it in there yet.
This is what I'm talking about (image taken from a different forum):
Old Nov 2, 2016 | 08:45 PM
johnnycf26's Avatar
I just cant seem to get the tube into the master cylinder far enough for that compression fitting part to go in...so the clip wont hold the line in place. Is it possible that the compression fitting has moved????
I'm trying to get this part:
Into this part: (Where the white cap is)
Old Aug 9, 2018 | 01:23 AM
JerRoy07's Avatar
Did you ever fix this? I am having the same exact problem. I took out the ECM box and tried putting a pry bar under it to push it in and it won't go in past the rubber part.
Old Oct 4, 2018 | 10:13 AM
BigBlueADR's Avatar
Default I've fixed this...
This is a case of "force is not a crime"...
I had mine halfway in, and bolted from the inside...use something for leverage onto the metal pipe, and force it in.
At first i was afraid to break something...but no, nothing broke....it eased over the little collar on the metal hose sothat the clip could be installed to hold it in place.
L
Old May 17, 2020 | 03:09 PM
badandboujeea4's Avatar
Default did you get this fixed because i cant seem to get it
L
im trying to get this thing in and it just wont budge and theres no room to really work so i dont really know what im pulling and pushing on to force it in
proctorb18
Jul 26, 2013 11:07 PM
tpaudi
Nov 12, 2012 12:36 AM
SS92
Sep 30, 2011 12:01 AM
Dallas09
Apr 7, 2009 03:16 AM
1781cc
Apr 26, 2008 12:11 PM
