MBC installed now not boosting over 5psi
Old Mar 20, 2008 | 10:43 AM
mr.cAp's Avatar
Default MBC installed now not boosting over 5psi
i instsalled my hallman MBC today with the information found on the forums, i removed the two hoses from the n75 and connected them to the mbc, leaving the electrical connection to the n75. now no matter how much i adjust it i will not boost over 5 psi. i am warming up and am going out in a second to make sure i didn't install it backwards, but any suggestions in the mean time would be helpful.
thank you
Old Mar 20, 2008 | 10:51 AM
new2me's Avatar
Default RE: MBC installed now not boosting over 5psi
I remember reading a few months ago about someone that had the exact problem as you. I think they either connected it backwards or did not have the n75 hooked up right. I do aquick search to find the thread im talking about.
Old Mar 20, 2008 | 11:18 AM
mr.cAp's Avatar
ok i checked, it hooked up correctly and all the lines are on tight, but i think i figured it out i think i just need to change the spring out and run it again
Old Mar 20, 2008 | 11:36 AM
mr.cAp's Avatar
wooo hooo, i love this thing, i spool so much faster and i am spiking at 17psi and holding 15psi to reddline, now if i can just get an Emanagment program that works with vista.
Old Mar 20, 2008 | 11:57 AM
Jeff's Avatar
Zombie Defense Force
nice good to hear you figured it out
Old Mar 20, 2008 | 01:40 PM
A4speed's Avatar
so im installing my mbc this weekend, what exactly did you do to fix it?
Old Mar 20, 2008 | 03:12 PM
Hernandez3011's Avatar
I recently installed my MBC also. I kept going into soft limp because i hadn't installed my a diode onto my map sensor yet.
Old Mar 20, 2008 | 04:32 PM
Jeff's Avatar
he just had to put a different spring in i think.
hernandez how are you running your n75?
Old Mar 20, 2008 | 04:42 PM
qUaTtRoA4's Avatar
#1- I want to see pictures!!!
#2- I have a speedtuing chip, and with just my redular old N75 I am spiking at 19 and holding at 15/16....
#3- what were you spiking/holding before the mbc?
#4- I also have the VDO boost guage, so our #'s shouldn't be very far off....
interesting, good to hear that you figured it out!
Old Mar 20, 2008 | 05:25 PM
mr.cAp's Avatar
ORIGINAL: qUaTtRoA4
I will have them up tonight
I Was spiking at 17 and was holding 5-7, My spool time seems like a fraction of what it was
My MBC came with 2 springs, soft and firm, originally i thought the directions said the soft spring would allow for 5 extra psi, and i found out that it meant that it will only allow for 5psi so i switched for the firm spring. i plan on taking it up a little further because of the chip, i cants get lemmingwinks, unisource or any vag software to work on my Vista laptop. i would like to fine tune the fuel and timming. but it realy is a simple install the majority of the wort was getting the rusted hose clamps off
