MBC or Race N75
Old Mar 26, 2008 | 12:25 PM
SuprA4's Avatar
Default MBC or Race N75
Should i attach the mbc so it bypasses the n75 or where does the MBC go in accordingly to the n75?? pictures would be best too!
Old Mar 26, 2008 | 12:55 PM
SLVR99A4's Avatar
Default RE: MBC or Race N75
Search tool would be your best answer; this topic has been covered quite a bit including a detailed diagram of it's application.
Old Mar 26, 2008 | 01:37 PM
A4speed's Avatar
just detach the n75 and put the 2 lines into the mbc, you don't have to split it off to the n75.
Old Mar 26, 2008 | 01:58 PM
B5 owns's Avatar
It depends if its a bleed or ball and spring. If its a bleed or a HPBC then you can just bypass, but if its a cheap ball and spring then you will have to run it inline.
Old Mar 26, 2008 | 02:18 PM
SLVR99A4's Avatar
An MBC installedin parallel as shown in the diagram below.
Old Mar 26, 2008 | 03:41 PM
pimphell's Avatar
I would just do the MBC
Old Mar 26, 2008 | 08:19 PM
mr.cAp's Avatar
ORIGINAL: B5 owns
i am running a ball and spring with no n75 just fine.
Old Mar 27, 2008 | 12:14 AM
SuprA4's Avatar
im just going to by pass the n75 all together then
Old Mar 27, 2008 | 12:23 AM
A4speed's Avatar
ya, its easier, and installing the mbc will only take a few minutes, im putting mine on tomorrow. the thing that takes time is adjusting it. what mbc are u planning on getting?
Audi Forums Editor
Jun 22, 2013 08:28 PM
Audi Forums Editor
Feb 12, 2013 04:38 PM
Jchockey100
Feb 6, 2012 08:44 PM
Stevenw83
Oct 26, 2009 02:12 AM
