Minimum rotor thickness
Old Nov 20, 2013 | 10:44 PM
Frozenguy's Avatar
Default Minimum rotor thickness
Hey what are the minimum specs for stock rotor thickenss front and back?
I'm getting a brake and light safety inspection and he said they will measure for minimum thickness.
Thanks!
Old Nov 20, 2013 | 10:58 PM
redline380's Avatar
Legal Moderator
Thicknesses are cast into the disks themselves
Old Nov 21, 2013 | 06:53 AM
M5S5's Avatar
Tech Certified
Front min .23mm or .908in
Rear min.8 mm or .318in.
Old Nov 21, 2013 | 04:56 PM
Frozenguy's Avatar
Ok thanks!
I have to replace them soon if not after immediately after the inspection.
Should I pay $30 more for the brembos up front
Audi B5 A4 Quattro 1.8T Braking Rotors ES#260950 Front Brake Rotors - Pair (288x25) - 8E0615301QKT4
over the zimmerman?
Audi B5 A4 Quattro 1.8T Braking Rotors ES#1895196 Front Brake Rotors - Pair (288x25) - 8E0615301QKT6
What about out back, $40 more for 'genuine OEM'
Audi B5 A4 Quattro 1.8T Braking Rotors ES#53 Rear Brake Rotors - Pair (245x10) - 8D0698601AKT4
over zimmerman
Anyone know how much I'd pay at stealership parts dept.?
Old Nov 21, 2013 | 05:45 PM
MetalMan's Avatar
How about Meyle (good quality) and free shipping at much cheaper?
MJM Autohaus
And for rear I'd go with these ATE (OEM brand), for a few $$$ cheaper and again free shipping:
http://www.mjmautohaus.com/catalog/p...oducts_id=2788
Old Nov 21, 2013 | 05:58 PM
Frozenguy's Avatar
thanks for the suggestion.
I'm happy with it as long as it's quality.
Those rotors and that shop is good to
go?
Old Nov 21, 2013 | 09:29 PM
Mad Cow's Avatar
Zimmerman is OEM and are the best OEM replacement rotors you can buy, I wouldn't go with anything else unless I was looking for a 2-piece setup. Meyle is ehh, I don't know a thing about their rotors but many of their parts aren't much better than no-name stuff. It all depends on how long you plan on keeping the car, if it's only for a year or 2 I wouldn't hesitate on buying cheaper rotors, but longer and I'd recommend spending the extra for Zimmerman.
Old Nov 22, 2013 | 01:01 AM
MetalMan's Avatar
I've been running Meyle A8 rotors on my A4 for more than 3 years now, with the same Hawk HPS pads (pads still have > 70% life left) and have never needed to turn the rotors. In fact I just moved the same rotors to my newer B5 A4 with new pads and still didn't turn the rotors, and the brakes feel great.
To each their own, of course, but I trust Meyle rotors. And I use their parts for lots of other parts... engine/tranny mounts, coolant tank, acc./AC belt tensioners, strut mounts, etc.
Old Nov 22, 2013 | 12:55 PM
Frozenguy's Avatar
She is getting inspected right now.
Pft.
I've put 40k miles on her since the accident and she is solid as a rock. I measured the rotors and they are good, pads are thick.
Nothing wrong with her.
About another 30 min left
Old Nov 22, 2013 | 01:57 PM
Frozenguy's Avatar
Wow. Dammit. Ok I didn't see this coming.
Says a lug bolt was stripped and locked into the hub, can't remove wheel.
Rotors are 0.5 mm below spec so they have to be replaced to pass. And I have to have this done today.
He told me that the bolt will hve to be brokeN and a new hub installed.
He doesn't have a new hub at the shop. So I'm getting the front rotors replaced and driving home with 4 lug bolts.
But I get my certificate, and my car registered today.
I drive soft, really.
I will get the hub replaced asap, but I have DMV to go to today and traffic court on MOnday.
