Misfires: p0300, p0302, p0322
Old Dec 26, 2012 | 12:44 AM
  #21
Giga's Avatar
Originally Posted by hauptjr
updates:
Car had increasing difficulty starting and more frequent stalls. Several times I walked away because the car would not start in parking lots. Never stalled and then failed to start - but I started to worry about that possibility and so limited my driving.
Wish I had spent a few bucks to get the sensor faster (I had taken the free ground shipping from autohaus AZ). But the problems were getting worse faster than I expected, and the stalling (and near stalls) were becomeing increasingly frequent.
Not the 25 minute install that I thought it would be. But that has more to do with my inexperience. Mechanic friend helped me out. We ended up doing all the work from above the car.
Tracing the cable was a bit fun, but ultimately it went under the oil filter. Moved the rad overflow, and removed the oil filter and then we could reach the sensor (with difficulty - long arms and experience working blind were important factors to success). (due to removing oil filter, we did raise up the car, remove the belly pan, and place an pan to catch dripping oil).
Ended up cutting the old sensor cable to remove it.
Now the car is working better, running smoothly and so far no stalls or problem starts. I should vag it and make sure there are no codes hiding (codes that didnt set off the CEL).
I put about 70 miles on it - not quite enough to be confident that all problems are resolved - but its looking good.
Thanks!
So it was your ENGINE SPEED SENSOR you replaced?
Old Dec 28, 2012 | 11:57 AM
  #22
hauptjr's Avatar
Yes - it was the engine speed sensor that was causing the stalling a few years back. It was a cheap part and a relatively easy install.
Old Apr 27, 2013 | 11:54 PM
  #23
MichaelBojsza's Avatar
where is the speed sensor and any idea how much to replace?
Originally Posted by Dallas09
replace engine speed sensor first, then clear the codes and see if the misfires continue, if they do it looks like coil pack since the code moved to a different cylinder, right?
Old Apr 28, 2013 | 12:03 AM
  #24
Expplucky's Avatar
speed sensors right next to the axel driver side google search the part so you can see what it looks like.
Old Apr 28, 2013 | 01:06 AM
  #25
Default engine light errors p0171, 0300-0304
is this a speed sensor issue?
2004 a4 1.8t
jwalters103
May 11, 2022 01:46 PM
p1zl3
Aug 23, 2016 08:33 PM
highlinemotorworks
Aug 20, 2013 10:31 PM
CALI KID
Sep 23, 2008 03:20 PM
a4sport
Sep 16, 2006 02:43 PM
