Missing ABS sensor - can I drive?
Old Jun 21, 2010 | 09:30 AM
vtraudt's Avatar
Default Missing ABS sensor - can I drive?
Broke the rear right sensor when trying to remove.
While waiting for a replacement sensor (that hopefully fits), can I get an alignment done and drive the car?
Or, will I have to take the rear hub apart again and need alignment to install the new sensor (currently, the 'copper sleeve' is still in the hole; not sure if a new/used sensor will come with it).
What is the car doing (aside from ABS and Brake dash lights on) with the sensor missing?
Old Jun 21, 2010 | 09:52 AM
hiwords's Avatar
yes you can drive it but the brakes may be a little weird. no mechanical or electrical issue will pop if you drive it.
Old Jul 22, 2010 | 12:44 AM
98_AUDI_A4's Avatar
Old Jul 23, 2010 | 02:21 AM
Dallas09's Avatar
When I had something similar happen, I decided to pull the ABS fuse. The reason being that when I braked, the car would brake funny and sort of steer the car when I braked. After I braked enough it would figure out there was a problem and turn on the ABS light, but it took a few times. If your ABS light is on all the time than I wouldnt worry about it, otherwise I would suggest pulling you fuse in the meantime (which will cause a flashing brake light combo btw).
Old Jul 23, 2010 | 10:57 AM
Mike-2ptzero's Avatar
Thumbs down
Originally Posted by 98_AUDI_A4
I was told i had to replace my right rear ABS/Speed sensor. How do i know which one is actually bad. I rather not replace something that doesnt need to be replaced. My Speedo works fine, just got the dreaded ABS light. Also, im not extremely familiar with Audi's.... Whats the easiest way to take it out?
You can have it checked with a Vagcom or the dealer can use their OBD2 tool to check to see which sensor is not working.
Old Jul 26, 2010 | 09:56 AM
vtraudt's Avatar
I replaced the broken sensor (right left), this one is working.
But (likely from wiggeling/turning to get them out), the front left is causing the fault. I tried to push it further in (at one point could hear the sensor touching the teeth, so move out a bit).
Is there an electrical check that I can do to see if I messed up the sensor/wires itself, or if it is a matter of positioning (gap)?
Also: still have not find good instructions to remove sensor (last one needed drilling out). Is the sheet metal 'cage' supposed to stay in the hub and the sensor pulls out? Or both?
What is the best method? Unplug sensor cable, then turn+pull? Leverage with tire iron/screw driver?
Old Jul 26, 2010 | 08:18 PM
98_AUDI_A4's Avatar
Old Jul 26, 2010 | 08:31 PM
hiwords's Avatar
if you have vag com, you can check the impulses on each sensor while driving. you can easily tell if one of them is showing numbers way off than the others.
as far as removing them goes, there's not much you can do. it's 2 different metals in contact and over time, they eventually fuse together
Old Jul 26, 2010 | 09:07 PM
vtraudt's Avatar
I tried just about everything but drilling out my right rear ABS sensor. PB Penetraing Spray(its been there for 12 years), Oil(figured it might slide out), Turning, Twisting, Prying, Banging. I even tried talking dirty to her hoping to coax her out. I must be doing something wrong. I prefer not to drill as the potential of ruining something and not being able to get the new one in. Anybody with more ideas?
Make sure to let me know if you ever get a good tip.
I destroyed one totally (ripped it off, had to drill out) and one partially (now error code on this one) when trying to turn the sensor to get it out (turns out its just the top with the cables/wires turning, the rest is stock solid).
I had the hub out, so drilling wasn't so much of a problem (drilled a bit smaller certainly, and had almost the entire sheetmetal cage still intakt).
But with the hub on, I wouldn't dare the drilling.
Old Sep 16, 2010 | 08:43 AM
vtraudt's Avatar
Default Replace ABS sensor front left
After replacing the right rear (working), we found that the left front is not working (we likely destroyed it when trying to remove it, possibly by turning the sensor CAP (we thought the entire sensor maybe turning) several times, ripping the solid internal wires?).
Need good advise how to go about replacing this one now. Preferably without taking the hub off.
If the hub has to come off: is alignment needed again?
