My A4 broke... Again!!! any help?
RE: My A4 broke... Again!!! any help?
thanks, yeah thats what im gonna do today, im gonna pull out plug by plug. im also gonna try and find someone with an OBD or something i can plugg that car into, so i'll post updates this afternoon.
Hi, I had the same problem with a previous audi I had. Start the car and get someone to run it just long enough to check the charge going to battery posts with a voltage meter it should be about 13.8 if not its bad alternator or bad voltage regulator. I had this exact problem, so I replaced the voltage regulator and that fixed it. hope this helps
thanks bro im deffinitely going to do that because im running out of ideas of what it could be... ohh and to everyone i couldnt get my hands on an OBD to check the codes im going out to buy one tomorrow so ill post the codes up tomorrow... thanks
well if you got a new battery that was fully charged, you could drive your car at least 10 miles lol. just turn eveything else off, i'm telling from experience lol. try pouring some fuel system cleaner down the gas tank too, it could be a rly clogged fuel filter
#18
Ok i got a code, AND WTF!!! i got 1545 Manufacturer Control Idle vehicle speed control/ Auxiliary input... ok i couldn't find a computer anywher e so i had to drive the damm thing to auto parts about .5miles away from my house! ok when i got back the headers weren't hot anymore but the car did smoke a little, i canme from the crack between the engine and the firewall, and ok, whne i got home, i knowdiced a buzzing noise coming from the fuel tank (like the noise a fuel pump would make).. wtf so i unplugged the battery and the damm noise was still there so i got under the car and tried to figure it out... nothing until i decided to take the gas cap off and the noise went away, also when i took it off there was a little pressure let out... i dont understand...???????? when i put it back on, i waited 5 sec. andthe noise came back, i think it's like pressure building up. i tried it a couple of times and it still wouldn't stop! about 1 and 1/2 hors later it stopped. any help guys??? sorry i took so long for me to get the code i couldnt fina a machine.
