My AWD doesn't move
So Tuesday night, I ran into a curb with my 1999 A4 1.8T. 219,000 miles. 5 speed.
Left front wheel took the impact. Wheel is pushed back 4 inches causing it to rub on the inside fender liner. Here's the question...
Why can I not move my car?
I can put it into any gear and let out the clutch completely and it doesn't move or anything. Thoughts?
Upon visual inspection, it looks like all of the ECS Tuning suspension parts, lower control arms, upper control arms and the sway bar, are all intact and not bent or out of whack. The only thing that it looks like is I'll need to completely disassemble the front end on the drivers side and break it all down. I will most definitely need a new cv shaft as it only spins occasionally. I wouldn't be surprised also if the wheel bearing is shot too. I wonder if I wouldn't be better served to try and find a new knuckle? Salvage yard maybe?
Well thank you all for your help! I had to replace the front lower rear control arm as it was basically taco'd into a 90 degree angle. I am in the process of replacing that and the axle shaft in this beautiful 3 degree weather we are having here right now. Thanks again!!
