my car is slowly turning into a paper weight...
Old Nov 3, 2008 | 06:07 PM
Jc61990's Avatar
Default my car is slowly turning into a paper weight...
ok so first I had a coolant or oil problem. Then a boost problem.... Now my car idles really weird. On my way to work, as I came to a stop, by car's rpms would drop really low then stall the car, I couldn't get my car started for 5 min. Then the whole way to work I had to put it in neutral and rev it a little so it didn't die on me.... WTF is going on!!!!!!
Old Nov 3, 2008 | 07:17 PM
ImTheDevil's Avatar
If I remember right, you mentioned in a different post that you have VagCom - at least for the time being, until the problems are sorted, use that to bump your idle up a bit. With my car, after a battery disconnect, it takes my computer several days to fully relearn itself and during that time it'll stall sometimes when coming to a stop or if I have to put the clutch in quickly (causing a quick drop in RPM). This is the case even though I do a throttle-body realignment first thing when the battery is hooked back up. Last time I had to deal with this, I met up with Hiwords and he upped my idle speed by 100RPM and I didn't have any more trouble with stalling. It's at least a temporary idea to try while you sort things out and it should help keep your car from infuriating you to the point of running it off a dock into a lagoon.
Old Nov 3, 2008 | 07:24 PM
Jc61990's Avatar
ok, thanks I'll have to try that, I'm kinds mad too cause today is re only day I took my laptop out of my car, so I don't hve my vag-com with me I'll have to do it when I get home
Old Nov 3, 2008 | 07:26 PM
ImTheDevil's Avatar
It's definitely worth a shot. My revs would still dip somewhat, but maybe only down to 500 or so before the engine would catch itself, and come back up to where it should be. From the moment we did that, I didn't stall out again. Hope it works for ya.
Jc61990's Avatar
sorry for spelling errors I'm on my iphone at work and it's built in spell check sucks
Old Nov 3, 2008 | 08:58 PM
a4r6's Avatar
What year is your car? from the looks maybe a 99? If so check your ICM.. Common mishap..
Old Nov 3, 2008 | 09:14 PM
Jc61990's Avatar
yea its a 99.5 says in sig.. im gona try the vag-com idle crap first then ill check the icm. im using the stock airbox so the ICM is still mounted on the top using the original heatsync so it should be good.
Old Nov 3, 2008 | 09:37 PM
Jc61990's Avatar
ok, i raised my idle to 910. and re aligned the TB again... i also did an auto scan for fault codes, and it stopped early with the HVAC getting an error.. heres the log
Code:
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
   Controller: 8D0 907 557 P
   Component: 1.8L R4/5VT MOTR AT D06
   Coding: 06251
   Shop #: WSC 06335
No fault code found.
Readiness: 0010 0101
Address 02: Auto Trans
   Controller: 8D0 927 156 BN
   Component: AG5 01V 1.8l5VT USA 8508
   Coding: 00000
   Shop #: WSC 00000
2 Faults Found:
00532 - Supply Voltage B+
            39-10 - Output won't Switch or Short to Ground - Intermittent
00526 - Brake Light Switch-F
            27-00 - Implausible Signal
Address 03: ABS Brakes
   Controller: 8E0 614 111 A
   Component: ABS/EDS 5.3 QUATTRO D10
   Coding: 0273004284
   Shop #: BB 24334
Address 08: Auto HVAC
   Controller: 8D  ö8 D08
   Note: Excessive Comm Errors
Old Nov 3, 2008 | 10:24 PM
onepoint8tee's Avatar
Do not mess with your idle with vag com. You are only covering up a problem by doing that. I didn't read any of the other replies, but it sounds like you have a vac leak.
Old Nov 3, 2008 | 10:30 PM
ryanylva's Avatar
^ true... you gotta leak! Do a pressure or smoke test
