my car is slowly turning into a paper weight...
Old Nov 3, 2008 | 10:52 PM
Jc61990's Avatar
Originally Posted by onepoint8tee
Do not mess with your idle with vag com. You are only covering up a problem by doing that. I didn't read any of the other replies, but it sounds like you have a vac leak.
im doing that tomorrow, im going by a friends that knows how to test for a boost leak and has all the tools to do it. hopefully we find it and fix it
Old Nov 3, 2008 | 11:25 PM
ImTheDevil's Avatar
I agree with that - I only suggested the idle adjustment as a stopgap measure to get him through until the trouble spot could be isolated. If it read as if I meant it as a permanent fix, I should've clarified that.
Old Nov 3, 2008 | 11:29 PM
Jc61990's Avatar
yea, once we fix my leak im going to put it back to the stock setting and hope it idles fine
Old Nov 3, 2008 | 11:30 PM
DÌEGØs AÜD!CTIØN's Avatar
good luck!
Old Nov 3, 2008 | 11:54 PM
Jc61990's Avatar
using this diagram... which lines are vac lines. so i know which ones to check if they need to be replaced... ill color the ones i replaced already in blue
i also replaced both the lines from the turbo to the n75
Old Nov 4, 2008 | 03:14 AM
redline380's Avatar
Legal Moderator
i have no idea what your problem is but let me tell you a story. i had a grand am gt. it kept breaking. if it didnt effect its daily driveablity IMMEDIATELY i just let the problem go. eventually, it got so bad i wanted a new car. i was fixing the thing constantly. i decided to get a good job and make enough money to get a decent vehicle. i ended up with the audi i am driving now. the other week, i had a cel. guess what i did about it? I fixed it. didnt let it go or anything. just plain got work done. and now what? it works like a champ. sorry to preach but thats exactly how you end up with a pos car. it breaks and you dont fix it. i wasnt fortunate enough to have a car like my audi a few years ago, but now that i am, i want to take care of it properly or i might end up like a pos like my grand am. fix it when its broke, and something thats broke wont cause another thing to break
Old Nov 4, 2008 | 03:16 AM
onepoint8tee's Avatar
Thats an inspiring story. Can you please shrink your sig pic by about 50%? Thanks!
Old Nov 4, 2008 | 03:27 AM
  #18
redline380's Avatar
Legal Moderator
^^^^i knew i wasnt goin to get told bout that sooner or later! believe, when i figure it out i will. been tryin...
Old Nov 4, 2008 | 09:18 AM
  #19
Jc61990's Avatar
download irfanview and shrink it...
and believe me. when theres a little problem wrong with my car i fix it... i dont mean to offend you, but i dont need you giving me advice on how i should solve a problem with my car... and yes it does affect daily drivability... when ever i come to a stop, my car stalls i have to put it in neutral and start it then if i hit the gas it chokes rpms drop to like 150 then fly back up and my car jerks alot. and now when im idle my vac is around 4Hg!
edit: and yes the idle is still messed up even after i changed the idle speed, so im going to change that back to normal when i meet up with my friend to test for a boost leak
Old Nov 4, 2008 | 11:42 AM
  #20
Jc61990's Avatar
ok, some one else told me it might be a clogged fuel filter... could that be a possibility?
