N75 -> wastegate question
I was wondering how the vacuum line from the N75 to the WG affects how the WG functions. Would disconnecting the line cause overboosting or cut off boost? Thanks.
The N75 regulates the vac/boost that actuates the waste gate. It overrides the 5psi waste gate spring to keep the waste gate closed and you in the boost.
If you disconnect the vac line to the wastegate you will only be able to boost to 5psi before the waste gate opens on its own, a form of fail-safe.
I agree that I've heard a few people say that our WG's have a 5psi spring. So I guess that's the least amount of boost that can be made.
