Need a Diagnoses
Old Feb 23, 2009 | 05:32 PM
deepshax's Avatar
Default Need a Diagnoses
Ive had a check engine light on for a few weeks now. I dont have the exact codes on me. But they were for engine misfire, and the engine running lean. Ive read around and have done some searching. I dont have any idling issues or start up issues or loss of power issues (minimal if any)...so i dont believe its a MAF issue. Im leaning more towards it being a vacuum hose problem.
But before i checked the hoses i wanted to clean the MAF just see if it would turn the engine light off before i tried to do anything with the hoses.
...im not really familar with whats under the hood or how to go about getting to/cleaning/replacing the MAF or redoing the hoses. ive also been looking around for a thread or place with some pics for a walk through. can anyone point in in the right direction. i have no doubt i can do the work (dont want to pay the dealership or shop to do simple work and charge me an arm)...ive done a good amount of work on my jeep (suspension work and drive lines etc etc.) i just want to make sure im not messing it up worse.
Old Feb 23, 2009 | 06:28 PM
ghost6303's Avatar
the maf is inside the airbox, its a black tube about 6" long, black mesh at one end, with sensor coming out of it at a 90* angle. if you think you have a bad maf, what you do is disconnect it so that the ECU runs off of a baseline map instead of reading the sensor. if your problems get better by unplugging it, then you have a bad MAF. if not, then you dont.
i would guess its more of a vacuum leak somewhere though.
Old Feb 24, 2009 | 10:15 AM
99audia4b5's Avatar
Clean the control unit its on top the air box and has 2 screws 8mm and 2 wires with clips clean where the 2 metal plates meet try that
tofast2belast
Nov 16, 2012 08:07 AM
Sidewayzracer
Sep 11, 2009 04:03 PM
