Need help Removing power seats that dont move. Please help!!!
Old Jan 17, 2012 | 10:49 AM
oneilclive78's Avatar
Default Need help Removing power seats that dont move. Please help!!!
I have seen the DIY on how to remove the seats but it requires you to move the seats back first. Is there a way to manually move the seats back so I can access the bolts to remove the seats?
Old Jan 18, 2012 | 06:25 AM
tunaoue's Avatar
Obviously, the seat adjustment is in the front of the seat. Pull up on it and the seat should slide forward and back. HOWEVER, I did experience a time where the passenger seat did not work properly for a couple of reasons. First it's an Audi. Second, the rails were sligtly off-kilter enough to jamb the sliding action. The remedy was to twist the seat side/back side/front and get it to "walk" into alignment such that it sat in the rails more correctly and the catch/lock mechanism worked again. Good luck with that.
Old Jan 18, 2012 | 08:26 AM
Thank you for your reply, but I hope what you mean is there is an manual seat override on the seats. I mentioned this in the heading that I have POWER seats as in NOT manual.
To be more clear:
I'm looking for help on removing my POWER SEATS. The seats currently do not move at all when you move the trigger. I would like to know if there is a Manual override to these power seat adjustments.
Thank you in advance for your replyies.
Old Oct 10, 2017 | 11:45 PM
bamhou's Avatar
Hi,
I am having the same issue with my a5. The power seats are not working and I need to be able to slide the seats manually on the rails.
Did you ever find a solution for this problem?
Thank you.
jkbaudi
Apr 8, 2013 08:25 PM
mboard182
Jan 8, 2007 05:51 PM
atticusx03
Jul 8, 2006 02:35 PM
onnfire
Jun 5, 2006 11:08 AM
