Need more HP, need advise
Old Sep 26, 2011 | 01:08 PM
MantasJM's Avatar
Default Need more HP, need advise
Hello. I got an 99,5 1.8tq. Allready made: full free Milltek exhaust, big FMIC, K&N sport air filter. Chip. And had 204HP and 270nM of torque. What is next? K03/04 turbo? Injectors? What injectors to choose? Can I put em from S3? Fuel pump? What would be the cheapest way for clutch? Thank you.
Old Sep 26, 2011 | 01:36 PM
TaConklin's Avatar
I wouldn't be putting in bigger injectors unless your ECU is tuned for it. Look into a test pipe or HFC. A test pipe will yield a decent amount of power and lower spool RPM's.
Old Sep 26, 2011 | 01:39 PM
CCA4's Avatar
You're making 204hp on the stock tune?
If you're going to go to the trouble to upgrade your turbo/fueling, I wouldn't bother with a K04. For a little more money you could go with a Garrett elim setup or Frankenturbo and make a lot more power.
Cheapest way to upgrade your clutch is to try to re-use the stock flywheel. As long as it isn't trashed, lots of places can resurface it for you and reinstall it with an upgraded clutch.
I suggest you PM Mike Hood (Mike-2ptzero)for both of these things.
Old Sep 26, 2011 | 02:17 PM
01quattro's Avatar
Not to threadjack, but how much can the tiptronic 5spd handle? I remember reading somewhere on here that its around 350? Could someone verify/clarify what it is.
Old Sep 26, 2011 | 05:40 PM
airguard350's Avatar
Tech Guru
300 is safe and 350 is pushing it. The weak spot, as with most autos, is the torque converter. I think with the TIP the valve bodies in tranny could probably be better too. You can build a strong TIP transmission it's just that most enthusiasts thumb their nose at automatics so the aftermarket focused on manuals. Plus, manuals have cheaper R&D and are cheaper to manufacture parts for since they aren't as complicated as an automatic.
Old Sep 26, 2011 | 06:22 PM
01quattro's Avatar
So im good to go as far as a K04 or stage 2+ ish, or so?
Old Sep 26, 2011 | 06:54 PM
Tech Guru
You should be. I'd definitely recommend fresh synthetic fluid and a fresh filter. If you wanted to switch to synthetic then you have to do a tranny flush with the fluid of choice since the tranny oil and the synthetic stuff won't mix well.
Old Sep 26, 2011 | 07:35 PM
01quattro's Avatar
To do that im assuming drain old fluid, refill as much as possible with synth fluid, then drive it around for a day or so and redrain/refill as much as possible? Or is there an easier way to get all of it.
Old Sep 27, 2011 | 02:48 AM
MantasJM's Avatar
I have read somewhere that people put vr6 clutch and it is stronger then stock a4.. is it true? is it easy to do that?
Old Sep 27, 2011 | 03:06 AM
Tech Guru
Many vr6 parts are better but I'm not sure if it's the same transmission set up since most vr6 cars are FWD.
