Need new bushings in front end
Old May 4, 2014 | 01:37 PM
Chipper's Avatar
Default Need new bushings in front end
Im Getting ready to order all the parts to change all bushings, tie-rod ends, and sway bar end links. I do want to put good quality parts and also wanted to know if its possible to get urethane bushings. My car is a AWD 1.8T model. Any suggestions and tips will be greatly appreciated. thanks!
Old May 4, 2014 | 04:48 PM
Huskerbob's Avatar
Have you considered buying a kit? Much easier to replace the whole shebang than to try to press out bushings etc. Lots of good kits on the market.
Old May 4, 2014 | 05:00 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Pick up Meyle's 12 piece Heavy Duty control arm kit and be done.
http://www.europaparts.com/control-a...0my-meyle.html
Old May 5, 2014 | 11:23 AM
Mad Cow's Avatar
I'd buy Febi over Meyle, but a kit is definitely the way to go. The ball joints wear out too and they're not replaceable. Don't get poly bushings unless it's a track car, and even then you'd lose a bit of suspension movement and steering angle since the stock bushings flex a ton at the limit while poly bushings can't.
Old May 5, 2014 | 11:41 PM
Chipper's Avatar
I just read another threw about Febi and the guy wasn't impressed at all with the kit or I mite be mistaking companies. I will definitely look into a complete kit and not just separate parts. And Mad Cow I will stay away from poly bushings, thanks for the heads up!
Old May 6, 2014 | 08:56 AM
Huskerbob's Avatar
I used a Meyle kit and all seems well. Nice and tight and much improved ride. Good luck. Make sure you torque at ride height. Very important.
Old May 6, 2014 | 09:12 AM
smittylube's Avatar
You can take my febi for shipping. I've changed 6 of 8 so far with lemforder. Maybe I got a bum kit but I doubt it. Only reason I've not swapped out the last one is because I'll have to drop the shock mount to get the bolt out.. At least mine drive right now.
Get lemforder do it once and be done
Old May 6, 2014 | 10:49 AM
Mad Cow's Avatar
I've heard more bad stories about Meyle than Febi, that's why I say that. My car currently has Febi arms with a date code of '06 and they still have at least another year before I have to replace them, so they definitely can last. At this rate it seems they'll last just as long as the OEM arms did on my car. Remember that nobody starts a thread about how their control arm kit went on perfectly and lasted years.
Old May 6, 2014 | 04:43 PM
Huskerbob's Avatar
Well my Meyle stuff went on without a hitch so now let's see how long the stuff lasts. So far so good.
Old May 7, 2014 | 09:56 PM
Chipper's Avatar
I spoke to one of the local shops I deal with for my VW/Audi stuff and he buys Lemforder (pretty sure that's the name he told me) and told me that's the only one he sells and can have it same day at the shop for me but its pretty pricey but hey has installed around 50 kits now and no complaints yet. So Im going to go with that kit.
Thanks everyone for the tips, its greatly appreciated!!
sned2
Aug 21, 2012 09:37 AM
jisungoppa
Sep 7, 2009 10:26 PM
B5luver
Feb 11, 2009 12:10 AM
TeeterTawter
Nov 24, 2008 01:18 AM
granite statah
Sep 15, 2007 08:55 PM
