Need suggestion on Tune and Injectors for GTRS Elim
I am looking for a Tune, fuel injectors and anything else I need to complete my project. I have been collecting parts for my 1999 Audi A4 AEB. This is what I have:
GTRS Eliminator Kit
Kenetic High Flow Exhaust Manifold
APR FMIC
3"TIP
3" Test Pipe and full exhaust
Forge 007 DV
225TT MAF housing
Walbro 225 Fuel Pump
2.0 Coil Kit
Does anybody have any suggestions on which tune, injectors and FPR I should get? Also, anything else I could be missing to get up and running?
GTRS Eliminator Kit
APR FMIC
3"TIP
Forge 007 DV
225TT MAF housing
2.0 Coil Kit
You could run Unitronics' BT tune with 415cc injectors, but I haven't heard very good things about them lately. Lots of customer service issues. Revo makes a 550cc tune that would also work but I don't believe they support Me5 ECU's.
Where are you located?
I'm inclined to suggest to you the tune which is on my car currently: United Motorsport AEB Stage 3. It's a 630cc file, which uses a 2.75" ID MAF housing. Also using Seimens 630cc injectors ($200 for all 4), and the ECS Tuning AFPR with fuel pressure gauge kit. Right now my fuel pressure is about 3.5bar, but I may be tweaking it.
One thing I'd like to point out: the TT225 MAF housing orients the MAF sensor perpendicularly to the stock AEB MAF housing. Many tunes for the AEB (including UM Stage 3) use the stock MAF sensor in a larger housing, with the sensor oriented the same as stock.
MK4 VR6 / TT225 MAF housing:
MAF Housing, "TT / VR6" 2.75" ID - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
MK3 VR6 MAF housing / what many AEB BT tunes use (the larger one):
Check out this thread for a similar thing to what I'm talking about:
Those with TT MAF Housing
Alternatively you can perform this mod to make your TT225 MAF housing work:
Fourtitude.com - how to make your MK3 maf sensor fit a MK4 VR6 MAF housing
Also thanks for the heads up on the MAF housing. Looks like I will be cutting and rotating the sensor mount of the TT one I have.
Before you cut the housing, I'd suggest you pick a tune and verify with the tuner that they require a stock sensor in a VR6 (MK3) housing. If they say yes, then you'll have to cut. It's not likely, but there's a chance they'll want you to use a different sensor in the TT225/MK4 VR6 housing.
Acuna989
May 2, 2011 01:11 PM
