new to audi and in need of some help
Old May 7, 2011 | 11:26 AM
bradtyler02's Avatar
i guess I'm using the emergency key. It's none flip, but opens the trunk and glove box. APR Tune
Old May 7, 2011 | 11:36 AM
audiltr's Avatar
Here is aprs instructions if you haven't seen them yet.
How EMCS Works
Step 1
Press and hold the "set" button on your cruise control. After approximately five seconds, the "check engine" light on your dash will begin to blink once per second. This will tell you that you are activating program one. This blinking sequence will continue for approximately five seconds.
After this five second interval, the "check engine" light will begin blinking twice per second. This will indicate that you have activated the second program. This process is continued to access any remaining programs you may have purchased. (three blinks = program three, four blinks = program four).
Step 2
Once you have activated the desired program, simply release the "set" button. The "check engine" light will stop flashing. Turn the ignition key off for 10 seconds, turn the key back on, and you will be locked in that program until you change it again.
Old May 7, 2011 | 11:40 AM
audiltr's Avatar
Assuming your cruise control stalk still work! As mine does not
