New clutch kit
So i just replaced my engine in my 2000 audi a4 2.8 and told shop to put new OEM clutch kit in as well. i got the car back yesterday and drove it around awhile and engine sounds awesome and have more power with new plugs/wires.
only issue is the new clutch...the mechanic i have known for awhile and i trust but the pedal/shifter feels EXACTLY the same as before. My brother was warning me that the new clutch would be stiffer and feel way different...i have noticed the shifting is exactly the same and the pedal engages exactly the same. Should the clutch be stiffer and engaging quicker with new OEM kit or are all clutch kits this easy going and soft?..
sorry for long read but any advice would be helpful...
your brother is incorrect. hell, if the pedal felt different, i would be concerned. not all kits are going to be soft, but all oem units will have the same feel. i run an s4 clutch with a lightweight flywheel. i killed it the first drive, but overall it didnt feel much different. you are definately good to go. if you clutch was shot and the new clutch feels the same, i might be concerned, but if you just swapped out disks and pressure plates, id hope it feels the same
I'm not sure why it would feel any different. If anything the engagement points might be slightly different depending on how worn out the old clutch was.
OEM clutches are self adjusting so as they wear they adjust so the engagement stays the same.
Jason
Jason
hmm if you read i was going from OEM clutch kit to another OEM kit..therefore they should feel the same according to popular opinion. "like you have to be an idiot not to realize" what we were talking about considering its right there in the thread..
My mistake sorry, I was referring to my car, I meant that if you drove my car before and after the new clutch and didn't feel the difference.
I have gone from worn oem to stage 1 s4 kit, clutch pedal to me honestly feels softer and yes the engagement point is almost immediate after letting go of the clutch. We'll this is how my car is responding after the install. Yes as you say oem to oem, the feel should stay the same as mentioned above
