NEW ICM didn't fix misfire! PLEASE HELP!
Old Mar 30, 2010 | 02:19 PM
AudiTurbo's Avatar
Question NEW ICM didn't fix misfire! PLEASE HELP!
Ok so I got in today a new ICM and it didn't fix my problem my misfire problem. When I go from first to second and roll into it, it feels like the car has hit a wall. It just studders and shakes until higher RPM when it clears out a little. The car still boost, but the car is so slow now. Could my problem be a plug, coil, or injector? I use bkr7e and gap to .028 and will be changing them tonight.. What else can I do?
Please help as much as possible.
Thanks!
Old Mar 30, 2010 | 02:56 PM
dragonrage's Avatar
Are misfires your only codes? Any of what you said can do that, and I think the "race" N75 can screw things up as well.
Old Mar 30, 2010 | 03:02 PM
AudiTurbo's Avatar
Yes misfire is the only codes..I can't find the bkr7e's anywhere...it just studders like it can't go anywhere. Maybe I'll change back to stock n75 and see what happens
Old Mar 30, 2010 | 05:30 PM
Calmingstorm's Avatar
Member
Hows your fuel pressure? And, you ask how if coil/plug/injector could be the cause...you didn't check the coils already? That's usually the first to go.
Old Mar 30, 2010 | 05:38 PM
AudiTurbo's Avatar
I have changed coils around,but still the same cylinder
Old Mar 30, 2010 | 05:41 PM
chocalotstarfish's Avatar
Super Moderator
do the same w/ your injectors!
Old Mar 30, 2010 | 05:48 PM
AudiTurbo's Avatar
Yeah I could try that.. Would it throw a cel?
Old Mar 30, 2010 | 05:50 PM
AudiTurbo's Avatar
Could it be a clogged cat?
Old Mar 30, 2010 | 06:01 PM
Super Moderator
a clogged cat wouldnt toss a cel for one cylinder.
Old Mar 30, 2010 | 06:07 PM
AudiTurbo's Avatar
True but sometimes it does happen in multiple cylinders. Has 132k so it might need to be changed
