new problem- REVS BOUNCING
Old Feb 15, 2008 | 03:38 PM
chaos92287's Avatar
Default new problem- REVS BOUNCING
here's the story, bout a week ago i install my fmic. worked great, except for the fact the hotside pipe kept blowing off. i bought some better couplers and t-clamps and just installed those today.
i also installed all new motor and tranny mounts a bout 4 days ago, but for the snub mount i bought just the 034 mount and not the bracket so when i drove the car there was some severe jerking anytime i went over ~20mph. so i ordered the bracket from 034, really loosely tightened the shroud and started the car, quite a bit of vibration, let it idle and the mount center itself, vibration went way down, finger tightened the bolts as much as i could, shut the car off, and then wrenched them completely tight. start the car again and at first it doesn't start. then i start it again and it turns over fine, but at idle the revs are bouncing up and down and i look at the dash and i have a CEL. great. bust out the vag, check the codes. (side note- the cel may have been there before, i wasn't really paying attention to the dash, but i really dont think it was there till then)
Address 01: Engine
Controller: 8D0 907 557 N
Component: 1.8L R4/5VT MOTR HS D05
Coding: 06201
Shop #: WSC 06335
3 Faults Found:
17584 - Bank1: O2S (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
16505 - Shareware Version. To Decode all DTCs
P0121 - 35-10 - Please Register/Activate - Intermittent
16486 - Shareware Version. To Decode all DTCs
P0102 - 35-00 - Please Register/Activate
so i got p1176, p0121, and p0102.
p1176 is cause of my test pipe (tho i installed the angle block and haven't seen a CEL till now, guess its just coincidence??)
p0121 is Throttle/Pedal Pos.Sensor A Circ Range/Performance. does this mean i have to do a TB alignment? i never disconnected the battery...
p0102 is Mass or Volume Air Flow Circ Low Input. im taking it thats my MAF? why would that be triggered?
i dont get why im getting these codes now, i just did the snub mount and dont remember seeing a CEL before today...
Old Feb 15, 2008 | 03:58 PM
hiwords's Avatar
Default RE: fault codes after replacing mounts????
could've damaged thethe downpipe and the flexpipe from the rattling. go check them out
Old Feb 15, 2008 | 04:10 PM
chaos92287's Avatar
nah they're both good. i dont remember seeing the CEL until that last time when i did the final tightening of the snub bracket. before then, i messed with the snub mount a number of times and drove it a couple of times, trying to diagnose the problem of the violent shaking, and never remember seeing a CEL. then i found out you NEED the 034 bracket, so the cars been sitting ever since. i dont remember seeing a CEL before then, but honestly i was more concerned with the vibration than looking for a CEL (not to mention the sight of a CEL is common to me since i drove around with one for so long cause of the testpipe) i barely noticed it before i shut the car off lol
Old Feb 15, 2008 | 04:16 PM
chaos92287's Avatar
i think im just gona disconnect the battery, clear the ecu's memory, do a TB alignment, and try starting the car again. the thing thats throwin me off is the MAF code. and the fact all 3 of these codes came on after doing a snub install and swapping the IC connections.
Old Feb 15, 2008 | 04:36 PM
chaos92287's Avatar
hahaha, just realized my MAF was disconnected. musta done that when i was messing with the headlights. lets go try this one more time...
Old Feb 15, 2008 | 04:38 PM
hiwords's Avatar
roflmao
Old Feb 15, 2008 | 05:31 PM
chaos92287's Avatar
so i disconnected my battery for 20 min and i still have a CEL. WTF? scanned it again and got this, this time
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Coding: 06201
Shop #: WSC 06335
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17584 - Shareware Version. To Decode all DTCs
P1176 - 35-10 - Please Register/Activate - Intermittent
P0102 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0110 0101
Address 03: ABS Brakes
Controller: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D31
Coding: 0273004134
Shop #: BB 24302
No fault code found.
Old Feb 15, 2008 | 05:33 PM
chaos92287's Avatar
the vibration over 20mph is gone. she pulls strong, but there is vibration at idle (enough to annoy me) and the revs still bounce up and down
Old Feb 15, 2008 | 05:35 PM
chaos92287's Avatar
just did a quick search and that p1602 code means the battery was disconnected or has a loose ground. well no ****, i disconnected it to clear the CEL, but it didn't, why is that?
Old Feb 15, 2008 | 06:29 PM
chaos92287's Avatar
my car is possessed or sumthin. went to take it for a drive and the CEL is magically gone, the car feels a MILLION times better. every shift is so smooth. you feel everything on the road (tally roads suck BTW) there's no more soft cushy mounts to absorb everything, i hit little bumps doing 50 around a turn and thought i was going to wipe out lol.
BUT at idle my car sucks *****. the vibration is annoying, but i can get over that. my problem now is, my revs are STILL bouncing, if im in gear its fine, if im at 40 and shift into neutral, my revs will bounce. if im sitting at a light my revs bounce. anyone know whats causing that? i noticed a little bouncing before i did all this crap to the car but now its waaay more dramatic and does it way more often.
