New torbo, no boost
Old Apr 25, 2010 | 01:09 PM
jhanson25's Avatar
Default New torbo, no boost
Got a new turbo on my '97 1.8t and the boost gauge shows I have vac pressure but no boost. It is very low on power. I don't have any check engine lights on either. The only thing I noticed after I ran it a mile or so was the bolt on the top right if the turbo (the one with the hole in it) has a little bit of air coming out of it. Any ideas? Its still smoking pretty bad from the exhaust but I think that's just all the oil from when the first one blew. Any help would be greatly appreciated! Thanks so much!
Old Apr 25, 2010 | 03:43 PM
joenelson7687's Avatar
Are you talking about the little nipple on the top? There shouldn't be any unaccounted for air coming directly from the turbo. Check to make sure that everything is hooked up and hooked up correctly. Check the wastegate to n75, n75 to turbo. Also, have you checked to see if you are in limp mode?
Old Apr 25, 2010 | 05:12 PM
FASTER's Avatar
Tech Slut
You mean the banjo for the coolant? You need to get it in there properly, there shouldn't be air coming out of it AT ALL. sounds like you have to bleed the cooling system too.
Old Apr 25, 2010 | 06:49 PM
jhanson25's Avatar
when installing the wastegate how much of an opening should I have left in it? Should I leave it open a tiny bit to allow air flow thru or have it all the way closed?
Old Apr 25, 2010 | 07:00 PM
FASTER's Avatar
Tech Slut
Closed
Old Apr 25, 2010 | 10:24 PM
jhanson25's Avatar
Got the wastegate closed and shes runs a heck of a lot better. Not really impressed with the acceleration but she handles like a dream! Thanks for all of your help!
TeeterTawter
Jan 20, 2013 12:14 PM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
Justin_72
Aug 11, 2007 08:56 PM
onepoint8tee
Jun 27, 2007 04:38 PM
Michael
Oct 28, 2004 01:58 AM
