No boost Gt2860rs Please help me
So I was about to go on a run today with a good group of people and my turbo wont make boost
It was driving perfect before, Cruzin on the freeway at 80 with lots of passing power.. Stopped let it idle for a couple mins as I was talking to a couple guys then shut her down.
Car sat for maybe 30 mins tops, went to start it back up to go on the drive and there was no boost...
I am completely stumped, boost gauge would go into vacuum 20/25 and wouldn't go above 0psi...
oil temps were a lil high at like 225 but within reason...
plently of oil still golden too! full synthetic mobil 1 0 40w
turbo has a brand new CHRA less than 200 miles on it
It was making a weird noise almost the exact same sound as a s4 with ko4s spooling down lol... pssswooo lol
Please help lets throw some Ideas around I am seriously bummed
Its a Gt2860rs
I did a boost test and I didn't hear any leaks. I was looking at my boost gauge and it was only moving like a cm. Its gotta be the turbo. Its making these weird noises..
So I took a video..
http://www.youtube.com/watch?v=Ut7pj_h4w1o
this is what it sounds like.. Kind of hard to tell but it sounds like metal on metal...
maybe this second video will help. You can def hear it still spinning after I killed the motor.
http://www.youtube.com/watch?v=sH7klKtcAs4
Again vac is at 20 and it wont go over 0psi on my boost gauge.
another video:
http://www.youtube.com/watch?v=y6Y89TjGYeQ
Its a Gt2860rs
So I took a video..
another video:
If you are getting the dentist sound then the turbo is dead. You might want to pull off the turbo inlet hose to see if there is damage to the compressor wheel or any shaft play.
That sound of the turbo when you turn off the motor is just wrong, it is uneven and a grinding sound which means there has to be damage to the wheel and the bearings are done.
If the CHRA only has 200 miles on it then you have a major issue with your oil flow to the turbo.
the elims use your stock oil feed line right? They get pretty constrictive due to sludge and buildup inside of them over time as I've heard.
Not duck tape... Heat shielding, from the stock oil feed line.
I am looking at this line:
http://cgi.ebay.com/ebaymotors/AUDI-...Q5fAccessories
F bomb I pray and hope its covered under warranty...
Update: I did a wastegate pressure test and the wastegate opens and closes.. there is no shaftplay.. what is causing my turbo to make these weird noises with no boost? I am going to replace the oil feed line. Is there a diy/writeup for this? I know you have to remove the intake manifold.
