NO CODES, Changed temp sens, why still hard start when warm?
Old May 4, 2008 | 07:38 PM
Stouffer's Avatar
Default NO CODES, Changed temp sens, why still hard start when warm?
Got a 01 A4 2.8L, starts fine when cold(now that the weather is getting warmer, even cold start is a little hard sometimes.) If i shut it off and let sit longer than 10 min, i have to crank it between 5 to 10 times before it fires up and when it does start, the rpm's rise very slowly, need help!! NO CODES, just got scanned. changes plugs, cleaned MAF, changed fuel filter, and I did change the coolant temp. sensor. Any ideas?
Old May 4, 2008 | 08:55 PM
david9999's Avatar
Default RE: Changed temp sens, still hard start when warm
Go get the codes read and post them back here.
Old May 6, 2008 | 07:31 AM
Stouffer's Avatar
I stated in my post that I am getting NO CODES. Any ideas? I dont think it is a fuel pump issue but not sure. maybe coils.
Old May 13, 2008 | 09:46 PM
Stouffer's Avatar
any ideas? anyone?
Old May 14, 2008 | 01:34 PM
kendalll's Avatar
guesses... how does it idle?
maybe the idle controller needs to be cleaned.
vaccum lines replaced.
throttle body cleaning / adatation
check MAF accuracy
tune up stuff:
new spark plugs
plug wires
I'll be curious what you find since my car isn't starting on the first crank now about 10% of the time.
Old May 16, 2008 | 07:26 PM
Stouffer's Avatar
thanks for the reply, every once in awhile it will have a really rough idle at startup, i have to hold in the gas or i feel like it will stall, only for a couple seconds then its fine. Theres almost always a strong fuel smell when cranking so maybe im not getting the initial spark but i just changed the plugs and a valve cover gasket(had a little leak). probly gonna clean TB next.
Old May 16, 2008 | 07:29 PM
Stouffer's Avatar
how do i check the MAF, OBDR? If so what numbers should i see?
Old May 17, 2008 | 04:39 AM
gio gio's Avatar
i had hard start on cold or warm engine did not metter. but just hard start, after the start idle was perfect. changing spark plugs helped out.
Old May 19, 2008 | 02:30 AM
kendalll's Avatar
you have to use Vag-com to check the maf numbers. if I recall correctly you should see about ~3-5g/s at idle but search on that and you should find the real numbers.
doomwalrus
May 7, 2012 01:13 AM
xzera
Sep 16, 2010 10:43 PM
cmbcannon
Apr 7, 2008 03:57 PM
jwd2a
Sep 27, 2007 04:11 PM
carlosgtn
Aug 25, 2007 02:38 PM
