no power steering
Old Dec 21, 2013 | 10:36 PM
Kamil`'s Avatar
Originally Posted by Kamil`
Open your power steering fluid reservoir to make sure that's engine oil. .
By opening the reservoir, he can verify that he is only leaking engine oil. If he had low power steering fluid, he could assume he has a power steering leak also.
The sentence was a response to his reply.
Old Dec 21, 2013 | 10:43 PM
HBAudi's Avatar
...The sentence was a response to his reply.
Thank you for correcting my misunderstanding.
Old Dec 21, 2013 | 11:11 PM
Kamil`'s Avatar
Actually I should apologize for writing such an unclear sentence.
Old Dec 22, 2013 | 12:09 AM
Pepsi_son's Avatar
the level for the power steering is just as full as it has been for the 3 months that i have driven the car. i have gone through about 7 quarts of oil in this time but have driven almost 5000 miles.
Old Dec 22, 2013 | 12:41 AM
Kamil`'s Avatar
Common areas of leakage are valve covers, tensioner and oil cooler. When I bought my B5 I had to replace the gaskets in all those areas.
Old Dec 22, 2013 | 01:42 AM
Pepsi_son's Avatar
i rebuilt the whole motor before i started driving the car... the pervious owner got the timing belt replaced and the tensioner failed causing a hole in the piston. all in all i replaced all of the gaskets but obviously it is leaking from somewhere. i will check all of those places when i am there next.
Old Dec 22, 2013 | 03:39 PM
HBAudi's Avatar
One area that sometimes gets overlooked is the valley pan gasket between the cylinder heads, which can cause a leak down the back of the engine onto the gearbox or starter motor.
Old Dec 23, 2013 | 05:55 AM
  #18
Kamil`'s Avatar
Oh that's right; that and the rear main seal, but being that you rebuilt the entire motor, I want to say I doubt it but you never know till you start digging under that hood.
Old Dec 30, 2013 | 05:35 PM
  #19
Pepsi_son's Avatar
its been a while. i have been busy with things. now the power steering works great after its beeen sitting for a day, after 10 or 12 blocks it starts to get worse like its been. and the pump is wining like there is a lack of fluid although the tank is full.
Old Jan 1, 2014 | 12:02 AM
  #20
HBAudi's Avatar
When the system warms up, air is being drawn in on the suction side due to a loose fitting.
a3turrell
Jan 14, 2012 05:23 AM
Lastb0isct
Feb 17, 2009 03:15 PM
Kobe Diesel
Feb 20, 2008 10:38 PM
