Octane Question's???
Old Feb 4, 2010 | 02:24 PM
Chewster's Avatar
Default Octane Question's???
I just bought a 2001 Audi A4 1.8T Quantro and I filled it up with regular gas and the check engine light came on. Would this normally happen??? and what should I do now?? What gas should go in it??
Old Feb 4, 2010 | 02:29 PM
Jeff's Avatar
Zombie Defense Force
You can get the codes scanned at autozone or some place and they can tell you what's wrong. You should fill up with 91 or better
Old Feb 4, 2010 | 02:51 PM
Chewster's Avatar
OK so do I need to flush the old Gas out?? Audi told me over the phone that is why the check engine light came on but I will get the codes read as well after work...
Old Feb 4, 2010 | 02:58 PM
Andrew149's Avatar
if your gonna put cheap gas us mid
Old Feb 4, 2010 | 03:04 PM
Chewster's Avatar
Not trying to use cheap gas guess I just didnt know...
Old Feb 4, 2010 | 03:06 PM
mikekey's Avatar
Your check engine light came on because you put to low of an octane in the car. It will run like crap. The 1.8T takes 91-93 Octane, aka PREMIUM pal.
Old Feb 4, 2010 | 03:09 PM
Andrew149's Avatar
i only run 93
Old Feb 4, 2010 | 03:10 PM
Chewster's Avatar
Should I drain the gas out or put a booster in or something??
Old Feb 4, 2010 | 04:31 PM
mikekey's Avatar
Just run it out, it won't kill the car. Or run it to half full and go get 91-93.
I switched from 92 to 93 recently, no real difference.
Old Feb 4, 2010 | 04:36 PM
Andrew149's Avatar
you can leave it just put 93 in when you get to half way or somthing
