Oh nooo !!!
i got a abs / brake light today i need to vag com it so see if it is a wheel speed senor or the abs module any Really good places i can send it off to and can i drive the car with it not in there while its getting fixed
If the brake light is combine with it, it is definitely NOT a wheelspeed sensor. Theres a small chance its a blown fuse or loose connection, very unlikely. Sounds like your ABS module. You can drive the car while the ABS computer is removed. Some recommend module masters, otherwise search audizine (its probably on here too), theres a guy that does it for like 50 bux, and a website that many use that charges a 100 to repair.
Haven't had the need to send mine out but a ton of people have and I've only seen 1 guy who had an issue but he also was being fairly unreasonable about it as well.
Also i mis-spelled his name before, its k0mpresd
