Oil leak problem. please help!
yesterday my b5 started to leak. but not right under the engine. it started leaking out under the middle of the car. it looks like the oil is collecting at the bottomof the pan and then while driving it flows back to the middleof the car and then when parked it leaks out throught tiny holes in the bottom of the frame. this could be nothing but im not sure, just wanted to see if anyone knew anything about this. thanks
if its tranny fluid, if you are AUTO, that is a very bad thing and you could be burnin up clutch packs as you drive it more. if its engine oil do like he said and take that pan and clean it out and keep it off, maybe put some cardboard under it to see where its coming from and if a substantial leak you should be able to see a difference in fluid levels if you check them regularly.
Check for a Hydraulic Chain Tensioner Gasket Oil Leak... buy this kit and fix it...
http://www.blauparts.com/audi/audi_v...rgasketleaking
I have a similar problem, yet my car doesn't leak from the underbelly pan, it leaks from somewhere else. I think the oil is coming from the back of the middle of the engine. I'm not sure where it's coming from. Its kinda frustrating not knowing what to do, since I dont know where the leak comes from.
