Oil over flow
Old Mar 14, 2009 | 05:38 PM
vintravaia's Avatar
Default Oil over flow
AUDI A4 2.8
I totatly did a dumb thing while changing my trans oil and motor oil at the same time.
I drained the trans oil filled and what not. and thought i had drianed the motor oil. I added motor oil to the engind that already had oil. then drove for a half mile till it hit me that i never drained it. so now i have this whine noise coming from the driver side of the engine. where did all this oil go? and how can i get it out? any suggestion? or am i screwed.
Old Mar 14, 2009 | 06:01 PM
Interceptor's Avatar
Drain it ASAP and get it filled to the right amount. It could blow out your seals.
Old Mar 15, 2009 | 01:00 AM
SAudi's Avatar
the whine noise is and empty trans. try putting in some lucas tranny oil in there, its a bit thicker and may help revive the bearings and gears. as for the engine oil i assume you already know to drain it.
Old Mar 15, 2009 | 10:03 AM
nova_ss672001's Avatar
yea dude sux, park it asap and like stated above pour in the right amounts in the right places...
and if you can get a hold of redline MT-90 that would be best for your tranny...
Old Mar 23, 2009 | 11:28 PM
vintravaia's Avatar
Thanks, so that whine noise you say is the tranny not the engine? i thought i filled the tranny to max. i filled till it flowed out drove around the block then filled agian. i did that four times. i will check agian.
You guys have any suggestion on thermastats that goes form cold to normal and then cold agian for the entire drive. then wont move i had this problem before my timing belt changed w/ pump and all from the stealership. but its the same agian. i thought is was the stat that was stuck on open...any idea?
Thanks again
Old Mar 24, 2009 | 01:01 AM
Sick Boy's Avatar
for the coolant temp gauge its your its your coolant temp censors you cant get em at autozone. and i would drain that oil out asap
Old Mar 24, 2009 | 09:52 AM
FASTER's Avatar
Tech Slut
I think the best thing YOU could do is let a mechanic work on your car from now on lol
Is it an auto or stick?
Old Mar 24, 2009 | 11:00 PM
vintravaia's Avatar
Thanks, the funny thing is im kinda mechanicaly inclined. just have a bad day!
i drained the same day it happened
automatic
Old Mar 25, 2009 | 01:10 AM
Tweaked's Avatar
automatic
You'll need a VAGcom to read the trans temp to fill your auto/tip trans properly.
Old Mar 25, 2009 | 11:10 PM
vintravaia's Avatar
dont have Vagcom. Any suggestion....
