ok, so.. power steering suction hose? 2.8 12v
the hose that connects from the pump to the reservoir, the one that goes under the valve cover between that and the timing belt housing, and goes from rubber to metal back to rubber, is leaking all over. the metal fitting is leaking where it bolts under the timing belt stuff, the part that the clamp connects on the other side from metal back to rubber is leaking, and both rubber ends are leaking also. this whole design just kinda sucks.
what i want to do is just run a rubber hose from the reservoir straight to the pump and avoid any connection points in between. the problem is, i don't know what size hose to use, and am unsure of why it goes from rubber, to metal, to rubber again. does the metal portion of the hose do anything special? is there a reason for it? other than charging 200 dollars, for a HOSE. blah. anyone else have this problem? anyone fix it? anyone wanna shoot me?
i have to flush the fluid once i do this because i ran out of fluid in nyc and had to buy whatever they had at a gas station, which was some noname whatever the hell it is. the reservoir says something about mineral oil in german i think. i went to pepboys and they had random hoses, but i don't know what size i need and don't want to take the thing apart and drain all the fluid in their parking lot if i can avoid it. plus, they don't sell anything that looks like the real fluid that i need for my pump.
so basically, i need to know what the metal part in the middle of the 2 rubber hoses does, if anything, and if i can just replace it with rubber, that is compatible with the fluid that i don't know where to buy? yeah, i guess that's it lol
The fluid is chf11s only!
The metal pipe is just that , a metal pipe. You really should replaced the hose with what should be there or you will look forward to replacing the steering rack & pump also when the hose starts to deteriorate internally.
but the metal also has rubber, so if it were to deteriorate it will regardless, no? i don't know if 3" of metal on a 2' long rubber hose would make that much of a difference. it just seems like a really odd design.
what brand fluid should i use? where can i get it lol.. i'm gonna empty the system and throw some new stuff in so i want to get the right stuff.
also, does anyone know how i can find the diameter of the rubber of the hose that's used before i tear it apart cause i only have one car so i don't want to disassemble it and have to put fluid in just to remove again to go buy the hose.
alright, so i'm going to flush the ps tomorrow and go to audi and get some chf11 fluid... about the hose though, anyone else replace it with a straight line instead of using the 200 dollar rubber/metal thing? i need to know how big the hose is to get a replacement.
I replaced mine about six months ago using 5/8" fuel line that I got from a commercial truck repair shop and a brass insert fitting up by the pump. No problems with the chf11s and the rack/pump has been behaving better than it has in a long time....I just couldn't justify paying the 2-3 hundred dollars that the stealership wanted to charge me. Don't forget to replace the crappy one time use clamps with better stainless steel ones
By the way, Advanced Auto Parts carries the CHF11s; atleast the one by me does...
