Oooh! Look at the pretty smoke!
Old Nov 16, 2012 | 10:11 AM
DoctorMemory's Avatar
Default Oooh! Look at the pretty smoke!
OK, so I was driving to work this morning and there was hardly any traffic so I was having some fun and basically putting my foot in it a lot more than I usually do. I stopped at a light and thought I saw some white smoke coming from under the hood, but since the car hasn't given me any trouble before I convinced myself it was just exhaust from the guy in front of me. Pull in to work and get out and there's a fair amount of white smoke blowing out under the hood and passenger-side wheel well. Pop the hood and the smoke is coming from the turbo/cat area. Smelled like a cross between burning paper and melting plastic. There wasn't any obvious source of the smoke, it seemed like the whole area was just hot. I haven't checked any codes yet (CEL is always on due to vacuum leaks), but I'm guessing the cat is clogged.
Car is an '01 1.8t Quattro tip with ~130K miles. Anyone have any insight? Is the cat most likely, or a turbo problem? Something else?
Old Nov 16, 2012 | 11:13 AM
CCA4's Avatar
Did you see any smoke coming from the exhaust? Any loud noises? How are your oil and coolant levels? Could be a number of things.
Old Nov 16, 2012 | 12:45 PM
No smoke from the tailpipe, haven't had a chance to check the water or oil levels, but temps were all where they should be. No unusual noises, still rides nice and quiet.
Old Nov 16, 2012 | 03:17 PM
Subarashī Kao's Avatar
probably a small oil leak you might want to look for it.
Old Nov 17, 2012 | 08:39 AM
CCA4's Avatar
Yeah I don't think it's a blown turbo. There would be lots of smoke, noise, and you wouldn't be making boost. Sounds to me like one of the oil or coolant lines in or out of the compressor housing has sprung a leak. Check your oil and coolant levels
Audi Forums Editor
Apr 17, 2014 05:08 PM
drummr8
Apr 5, 2013 11:52 AM
halik
Apr 3, 2008 11:48 AM
bcart82
Apr 16, 2007 02:28 AM
