P0012
Old Oct 11, 2009 | 01:47 PM
AudiCross's Avatar
Default P0012
Cam position sensor error. I believe the problem is the cam chain tensioner for their variable valve timing. The shop that rebuilt my head i think clogged the port allowing oil into the piston with silicone. Just checking, is this the right code that would show up from that? The other people that i have read about replacing that part had different error codes.
PS Sorry about being away, I am still trying to get my car running up to snuff after the whole melting thing and the rebuild, but if this is the problem, All i have left that i know of is replacing it and gettin a new fuel pressure regulator
Old Oct 11, 2009 | 04:51 PM
CRAZYHAWK's Avatar
16396/P0012/000018
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 16396/P0012/000018 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
Possible Symptoms
Erratic Idle
Possible Causes
Intake Camshaft Adjuster tight/stuck
Intake Camshaft Adjuster faulty
Possible Solutions
Check Intake Camshaft Adjuster
Use Output Test, Meas. Value Blocks (MVB) & Basic Setting
Old Oct 16, 2009 | 05:41 PM
AudiCross's Avatar
That comments on the intake camshaft. I may be understanding that wrong but the intake camshaft is directly connected to the crank with the timing belt, the exhaust cam is the one that is adjusted by the adjuster
reaper1976
Mar 21, 2014 01:04 AM
supradibbs
Dec 23, 2011 12:01 AM
Alcaraz_D
Apr 21, 2011 10:53 AM
auditrt
Apr 3, 2010 03:31 AM
willk824
Sep 30, 2007 06:05 PM
