p0134
Old Jan 29, 2010 | 08:29 PM
Mr. Phil's Avatar
Default p0134
i keep getting this at random, which is no flow packets detected for o2 sensor... but when i reset it with my scanner it comes on at complete random times, would this be a short in the wiring or something else?
Old Jan 29, 2010 | 08:42 PM
audirpm's Avatar
It's def. pre-cat on bank 1. But yes its either going to be an issue directly at the o2 connector or wiring. It can also be an issue with the ECM unfortunately. The code is set as soon as the voltage is between 370mV and 430mV for longer then 4 seconds, and 123 seconds after engine start and engine temp. over 86 degrees F.
Old Jan 29, 2010 | 08:51 PM
Andrew149's Avatar
dont worry i have 2 bad o2 sensors u can only imagine my 260miles on a full tank
Old Jan 29, 2010 | 11:55 PM
Mr. Phil's Avatar
well smog time is this month and i kinda need to figure out how to fix it asap lol
sbm007
Oct 27, 2013 12:00 PM
stephenmalone
Jun 12, 2013 01:01 AM
themetalman
Jun 12, 2013 12:11 AM
jiggleo
Jan 19, 2010 08:08 PM
quattrolove
Nov 17, 2007 12:41 AM
