P0340 code intermittently pops
Old Apr 4, 2013 | 02:21 PM
sincityaudi's Avatar
You don't need to tare the front end off just the top timing belt cover and look at the cam sprocket mark and when it lines up with the arrow make sure you crank pulley mark lines up as well
Old Apr 4, 2013 | 02:22 PM
oh i see what you meant, the timing chain, yeah you gotta pull the valve cover for that part. best of luck and let us know what you find.
Old Apr 4, 2013 | 02:33 PM
dmount76's Avatar
Don't you have to pull the bumper, radiator, etc to see the crank pully mark?
Old Apr 4, 2013 | 02:44 PM
redline380's Avatar
Legal Moderator
not really. you could probably see it from up up, but it wouldnt be very clear. personally, id go through the 30 minute procedure of taking the front end off. it will make things much much easier in the long run
Old Apr 4, 2013 | 05:35 PM
no you don't need to pull anything but the top cover to see the cam marks.
Old Apr 4, 2013 | 11:40 PM
dmount76's Avatar
Posting this on audi forums must have convinced my car to fix itself. Cel went out by itself the other day and has not come back on yet. Maybe you guys worked some audi Jedi magic on it!
Old Feb 8, 2015 | 11:22 PM
dmount76's Avatar
Came back on shortly after this and developed a rattle. Eventually replaced the timing chain tensioner but the P0340 remained. After several months I finally figured out that the timing chain that connects the cams was stretched. I replaced the chain and no more code and got some lost power back too. Hope this helps someone in the future.
brico
Feb 4, 2014 10:49 PM
reserviceswpb
Oct 17, 2013 01:34 PM
stasAudi
Oct 28, 2009 07:26 PM
mattski1212
Jan 10, 2009 09:54 PM
luckky13
Aug 30, 2007 05:45 PM
