P1136
Old Jan 11, 2011 | 08:52 PM
thebeav's Avatar
Default P1136
Hey everyone
So I have a 98 audi a4 1.8t and I am getting increasingly annoyed at this p1136 code that my car is throwing. I know that it means that the system is running too lean, most likely due to a vacuum leak somewhere in my intake system. So I took it to a shop and they completely overhauled my pcv system and it was supposed to fix my problems.....but it didn't. I have been looking through the service records for my car and it seems like this p1136 just keeps coming up and has never gone away. The car is chipped so I was thinking that maybe the stock wastegate was shot or is sticking open which is causing it to run to lean? basically I was just wondering if anyone else has had this same problem and fixed it somehow. I live in california and i need this cel off in order to pass smog, so any tips on how I can do that would be much appreciated.
Old Jan 11, 2011 | 09:10 PM
Tourbo24's Avatar
probably a bad MAF sensor
Old Jan 11, 2011 | 09:16 PM
auditech79's Avatar
A stuck wastegate? That rediculous. Thats a LONG term fuel trim code, meaning it has to be a very small leak. The PCV system being overhauled is good in all but you must have a vacuum leak somewhere, and there is a LOT of places it could leak. The most common place is the vacuum check valves, then under the intake manifold.
My advice is to buy a bunch of 1/8 vacuum hose, and three of those vacuum check valves http://www.ecstuning.com/Audi-B5_A4-.../Check_Valves/ (bottom of the list) and see what happens. If you replace all your lines and those valves it should fix your problem.
You may even find you issue when you're replacing those lines.
Old Jan 11, 2011 | 09:17 PM
auditech79's Avatar
Possible, but not nearly as likely given the code.
Old Jan 11, 2011 | 09:28 PM
thebeav's Avatar
ok I will try replacing those lines and the check valves. It has a brand new maf so that isn't it. Thanks guys
Old Jan 11, 2011 | 09:56 PM
chocalotstarfish's Avatar
Super Moderator
I fought with my 1136 ended up as the maf was bad. I know u say urs is new but its always possible for it to be bad from the store.
Old Jan 11, 2011 | 10:09 PM
auditech79's Avatar
^^especially if its a kragen or autozone type of part.
jamestown478
Jun 27, 2011 12:11 AM
sivak.puvvula
Jul 15, 2010 11:11 AM
Audacity
May 18, 2009 12:19 PM
sound227
Jul 17, 2007 07:45 PM
jaydubyagee
Dec 3, 2006 11:23 PM
