Parking Brake not working
Hey guys,
So my parking brake does not work at all. When you pull the handle it's like it wasnt even connected to anything. The callipers in the back are fine so my guess is the cable itself is broken? How can I check? If it is broken where can I get a new one?
Thanks
Thanks
I had the same issue.
Turn's out there are adjusters under the car (more towards the back of the car) to Adjust the eBrake.
I can't remember where exactly, but follow the ebrake cable and after it splits into both directions towards each wheel. There should be a metal housing which you can turn clockwise/anti-clockwise to adjust it..
There should be an adjustment on both cables, its about midway on the car right in front of the axle. You have to pop the locking collar off then twist the tighting nut until the brake cable is taught. However if its never been broken loose in 10 years good luck.
G.B.G.
Jan 12, 2008 12:35 AM
datimez
Mar 30, 2006 09:40 PM
