Passat Column Pod
Old Dec 30, 2007 | 10:25 PM
erikas3's Avatar
Default Passat Column Pod
Have any of you guys modified the Passat column pod to fit our Audis? If so, was a lot of work needed?
Old Dec 31, 2007 | 12:20 PM
B6er's Avatar
Default RE: Passat Column Pod
won't work. Different shaped base/column. Podi.ca or newsouth performance, depending on B5 or B6/7. I should know, I tried to fit my column pod from my B5.5 Passat on my B6 A4. No dice.
Old Dec 31, 2007 | 02:37 PM
erikas3's Avatar
Damn.. I really liked the look of the Passat column pod from newsouth.. Thanks for the heads up!
Old Dec 31, 2007 | 04:39 PM
ocadam's Avatar
Did you ever get your car running good?
Old Jan 1, 2008 | 01:01 PM
erikas3's Avatar
ORIGINAL: ocadam
I don't know what you mean.. Other than electrical problems and the slowly dying original clutch, my car is in very good condition for 120K.
Old Apr 24, 2008 | 02:41 AM
pyropenguin's Avatar
check out the podi.ca pods. They're in pre-release right now. The designer is seriously the MOST **** designer I've ever seen, and those pods are top notch. It was delayed for a couple of months because the fit was like 1mm off.
Podi. Do it!
Old Apr 24, 2008 | 03:48 AM
oettinger1919's Avatar
SoCal Crew Member
Ya that 42 degrees company makes a sweet pod but no it does not fit the audi. i almost gambled and bought it anyways but decided not to. there just arent many options for the cars and those vent guages are just boring IMO
I plan on buying one of those cheap pilliar pods and just apholstering it myself, lay down some thin dense foaming and cover it with some suede or velour.. niiice! i actually forgot about that mod, im going to have to get back on it lol.
Old Apr 24, 2008 | 08:54 AM
Lazer Viking's Avatar
ORIGINAL: pyropenguin
Podi. Do it!
a couple of months ? it was supposed to be release LAST spring
iirc correctly they had 2 redesigns, 1 for color or texture or something, and the other for fitment
winston is nuts, but hes got my vote [up]
Old Apr 24, 2008 | 10:26 AM
klum00's Avatar
yeah from what i've seen winston's gauges are top notch.
Old Apr 24, 2008 | 02:41 PM
ORIGINAL: Lazer Viking
Podi. Do it!
OH! haha, I wasn't sure if it was this march it was supposed to be released or last spring, whoops!
Those two redesigns sound right though.
'oooo'
Apr 11, 2010 10:27 PM
slcrobo
Oct 22, 2009 06:35 PM
TOMMYTREETRUNK
Aug 22, 2008 05:50 AM
geramy
Feb 3, 2008 07:20 PM
EnviedA6
Jun 6, 2007 07:25 PM
