PCV location on a 1999 a4 quatro 1.8t
Old Dec 11, 2010 | 08:55 AM
wtlee3's Avatar
Default PCV location on a 1999 a4 quatro 1.8t
Can anyone tell me the easiest way to replace the PCV valve on a 1999 a4 quatro 1.8t? I don't see it anywhere.
Old Dec 11, 2010 | 09:42 AM
CCA4's Avatar
it's on the turbo inlet pipe just south of the airbox. This picture is sort of an odd angle, but its the best one i could find. The corrugated bit you see at the bottom is the turbo inlet pipe. The thing to the right of the red circle is the PCV valve. Above the circle, you can see part of the exhaust mani.
If you're going to the trouble, you might think about replacing it with a catch can. This DIY is for the MkI TT, which has a transversely mounted 1.8T, but the same general principle applies to yours. Hope that helps!
anthonystempak
Dec 11, 2014 03:47 PM
anthonystempak
Dec 11, 2014 01:21 PM
lianne_m_jones
Oct 13, 2013 05:00 PM
EuroSlut
Mar 25, 2012 12:29 AM
tonym
Nov 15, 2005 09:43 PM
