PCV Locations?
Old Jul 18, 2013 | 03:03 PM
bcmobilenotary's Avatar
Default PCV Locations?
I have a 1997 Audi a4 quattro 2.8L 12v... Replaced all gaskets including head. On my valve covers are the pcv (brittle plastic tubes that run to TB) that connect to a plastic intake that runs into the TB. My friend was helping me with the car and after getting it all back together he brought me a extra piece he forgot he had put in his car. He said it is a pcv valve and said it goes into the valve cover. The extra piece has a valve on it with a L connector on the other end (which connects onto a nipple somewhere?). He said it was used to relieve pressure in the crankcase. I went to the mechanic this morning and he said it connects to the valve cover and there should be a rubber to plug it into, again there is no rubber piece to plug into....Please help me locate where this piece goes!?!?!?!?!?
It won't let me post a pic of it.
On a side note, the one end is round and metal and has some kind of internal blocker to stop airflow (assuming airflow).
Old Jul 19, 2013 | 01:01 AM
Expplucky's Avatar
post a pic of your valve covers and ill show you where it goes,
if you look on the end of the valve covers youll see a little hole on the top of the cover with a lip around the end it hooks on to that.
p1zl3
Apr 7, 2009 04:49 PM
a2thy
Nov 12, 2008 12:24 AM
ryanylva
Sep 12, 2008 06:03 PM
rh1231979
May 2, 2008 11:13 AM
Too Tall
Jul 31, 2007 12:50 PM
