phantom coolant leak.
Old Feb 22, 2011 | 04:29 PM
Audacity's Avatar
Default phantom coolant leak.
so before winter i got a mk3 jetta on coilovers, so i could raise it for big snow storms. my a4 is on springs and its just to low to get over a lot of inches. anyway to make a long story short, i parked the a4 and occasionally started it to keep it running. today i went out to change the battery since the old one had died and there was no more coolant in my tank. i can see no where that it leaked from the temp sensor housing on the back of the block was replaced like 15k ago nothing from the radiator or thermostat anyone know where else is a problem leak spot its got just under 150k and its a 99.5 1.8t
Old Feb 24, 2011 | 10:42 PM
alexpf's Avatar
check the back of the motor for a leak. most likely is the coolant flange. mine leaks a little bit. i just check the fluid every time i fuel up. I didnt think it was worth spending $600 on getting it fixed.
Old Feb 24, 2011 | 11:28 PM
erasmmuss's Avatar
dude 600 to fix the coolant flange do you own a bentley or something? The fix will cost about 50$ and some elbow grease
Old Feb 25, 2011 | 09:18 AM
Audacity's Avatar
yeah as I stated above the coolant temp sensor housing is the coolant flange and was replaced 15k ago for about 50 bucks also I could see if it leaked from there I can't seem to find anything that looks or smells like coolant or even dried coolant nothing is in the oil so no gaskets Are bad I can't find anything
Old Feb 25, 2011 | 03:16 PM
auditech79's Avatar
Who installed the flange? It VERY easy to twist or pinch the seal between the flange and the head, thats what my money is on. You need a flash light and a mirror to look under the flange, its not visible without one.
Cioffie
May 19, 2013 10:24 PM
azr3al
Dec 30, 2011 12:37 PM
inventorA6
Apr 15, 2009 06:46 AM
less_of_me
May 2, 2007 03:29 AM
