Please someone help me!!
Old Nov 4, 2011 | 09:11 AM
solidecho's Avatar
Default Please someone help me!!
Hey everybody! I was offered this car after the owner brought it to a mechanic close by to where I work, I don’t really know what happened. But what I heard was that it came here on a truck but it was driven into a parking spot close by, so he was just getting less power or something. Then it just stopped starting up for some reason after that, I don’t even know if anyone even touched it.
Well now I got the car back in the house and I went out to check the car with my mom. I had her crank it while I was listening to see if I heard the fuel pump under the car by the passenger side rear wheel. After 2 times, my mom said she smelt something burning. I open the hood and I see a little bit of smoke simmer up by the right of an engine then go away (smoke only came out that one time, no smoke all the other times we tried). I went back to listening to the fuel pump and I thought I heard a little engine go on and for 1/4th of a second after my mom stopped turning the key.
I made a video of what I was just talking about right here:
1998 Audi A4 1.8T Wont Start - YouTube
Please it would mean the world to me if anyone were to give any suggestions on the problem and solution for this car.
Thank you.
Old Nov 4, 2011 | 01:02 PM
ckrummy's Avatar
The smoke kind of sounds like a starter wire overheating, But as far as it not starting, did you check the timing belt, kind of sounds like it might have jumped or broke, You need 3 things to start, Compression, fuel and spark, so if it's not the timing belt i would start by a spark check, and if you have it run a compression check too while you have the plugs out.
Old Nov 6, 2011 | 11:07 AM
solidecho's Avatar
Okay is there a way to check the timing belt without having to jack it up? I got a lot of scrap metal in my drive port and I still have to figure out how I'm going to get rid of it. And what exactly would I be looking for in a bad timing belt? Not spinning? Lateral movement? Missing teeth? Sorry I'm not too mechanically savvy so sometimes I have trouble understanding these things.
And the last time I tried starting the car, like I said in the description for the youtube video, my friend said he saw a big spark in the top right of the engine bay. Could this be a starter as well as timing belt kind of issue?
