possible bad INNER cv joint?
Old Oct 23, 2019 | 11:57 AM
Randybutler's Avatar
Default Help
Originally Posted by jiggleo
okay here is what I got off a website of a cv joint supplier. "A bad outer Audi axle shaft CV joint will make a clicking noise when accelerating and turning from a stop sign.
This is a strong indicator that the outer Audi CV joint is worn. As a general rule the inner Audi CV joint seldom,
if ever, makes this clicking noise. The symptoms of a bad inner Audi CV joint on is when vibration,
shuddering or torquing is felt through the cars steering wheel and is noticed upon straight line accelerating
(steering will pull to the left or right). " I will get underneath and check though.
I'm having the same problem with a 2008 s-line A4 2 liter turbo front wheel drive only bad vibration Frontline acceleration replaced axles first said I replace it destroyed passenger side had to replace it again still doing the same thumping vibrating what could be causing this
Old Oct 30, 2019 | 04:00 PM
george1546's Avatar
Could be warped or damaged disk brakes, your car will pretty much shake all the time when getting up to speed on highways and bad roads don’t help as well.
Regards,
George
Old Mar 30, 2020 | 08:03 AM
jay jay's Avatar
Angry shudders noise on left front wheel
hi.
i drive a VW MK1 FOX 1992 automatic. i noticed that i have a shuddering noise on left front wheel and it does it when hit about 60 mph and goes quite after 90/95 mph. Some guys told me that it could be my automatic gearbox because my car does not change gears like it suppose to. i have to drive it about 3000 RPM and then only it will change the gears but it has to be at 3000 RPM because the previous own never changed the clutches or clutch on the gearbox. i also heard that it could be my inner CV. COULD SOMEONE PLEASE HELP ME...
Old Mar 30, 2020 | 08:07 AM
jay jay's Avatar
It goes quite at 90 mph but does that mean i will have trouble meaning wheel pop out?
Old Mar 30, 2020 | 08:13 AM
jay jay's Avatar
that is exactly what my car does
Old Mar 30, 2020 | 08:17 AM
jay jay's Avatar
is it possible for tire to have the shuddering effect. some guys told me that it need balancing, rim might be slightly bend or could be the tread of the tire. correct me if im wrong
johnnieb
May 31, 2013 12:50 PM
jinsojoo
Nov 11, 2009 05:59 PM
SuperSquid
Oct 5, 2008 11:39 AM
FOZZIE BEAR
Jan 6, 2008 02:07 PM
boastud
Sep 25, 2006 01:31 AM
