CV Joint Help!
Old Sep 21, 2006 | 05:54 PM
boastud's Avatar
Default CV Joint Help!
Im hearing a popping/grinding on the rear driver side wheel. I am replacing the rear wheel bearings, but was told that the cv joint also needs replacing. 2001 S4, does anybody know how long its supposed to take to replace it, or if anybody has done it, how hard it is? Thanks in advance.
Old Sep 22, 2006 | 08:31 PM
AWDaholic's Avatar
Senior Administrator
Default RE: CV Joint Help!
have you tried doing a SEARCH <---hint: click link
Old Sep 25, 2006 | 01:31 AM
dankhound's Avatar
It should be about an hour additional labor from the bearing. Half of the shaft must be removed to get to the bearing. So all you have to do is replace the joint.
johnnieb
May 31, 2013 12:50 PM
jinsojoo
Nov 11, 2009 05:59 PM
SuperSquid
Oct 5, 2008 11:39 AM
hartsoe1
Aug 25, 2008 07:28 PM
FOZZIE BEAR
Jan 6, 2008 02:07 PM
