power steering pump?
Old Dec 27, 2007 | 01:48 AM
pimptrooper3000's Avatar
Default power steering pump?
whats upguys, so today all of the sudden out of no where my power steering dies... it only works when the engine is reving (works fine a little on the heavy side but fine); but doesnt when idling. im thinking power steering pump? does anyone have any other ideas on what it could be? also how hard is it to fix (i would like to do it myself) and how much would a new one cost? thanks guys
Old Dec 27, 2007 | 02:38 AM
Default RE: power steering pump?
no one can help???
Old Dec 27, 2007 | 10:46 AM
CRAZYHAWK's Avatar
Check the level of P/S fluid. Add 11S if needed.
Old Dec 27, 2007 | 11:24 AM
where is it... its not the same as the clutch and brake container right?
Old Dec 27, 2007 | 11:25 AM
also can i damage anything while driving without power steering??thank you
Old Dec 27, 2007 | 11:55 AM
CLX's Avatar
CLX
Zombie Defense Force
Power steering fluid acts as coolant for the system, and lubricant. Driving without it will shorten the life of all the p/s components. Was it making any odd noises, like a whine when you turned the wheel before it died? It sounds like you're out of fluid
Old Dec 27, 2007 | 01:03 PM
yea it makes whining noises... what kind of fluid do i need and where is the container for it? thank u
Old Dec 27, 2007 | 03:16 PM
i just added some fluid. i turned the car on and it still doesnt work; now that whining noise is even louder. i also noticed a leak comin from the pump area. i am not sure if it is the actual pump or one of the hoses. how would i check which one it is?? any other ideas? thank you
Old Dec 27, 2007 | 06:16 PM
CRAZYHAWK's Avatar
Only use VW/Audi power steering fluid, 11S.
Old Dec 27, 2007 | 06:20 PM
CLX's Avatar
CLX
You could have f*cked the pump up by letting it run dry, and even more so (rack, too) if you didn't use Auid/VW power steering fluid.
