problems on startup
Old Aug 3, 2010 | 12:55 PM
keef1979's Avatar
Default problems on startup
I've got a 2001 A4 1.8T. After starting, it sputters for 10-15 seconds, with CEL. If I press the accelerator, it revs unevenly and the turbo doesn't kick in. After the 10-15 seconds, it runs just fine. Any ideas on what's going on?
Old Aug 3, 2010 | 01:42 PM
joenelson7687's Avatar
Is your check engine light flashing ever?
Old Aug 3, 2010 | 01:45 PM
keef1979's Avatar
Default CEL flash
Sorry, I meant to include that. The CEL does sometimes flash when I press the accelerator, then stops flashing once the car begins to run normally.
Old Aug 3, 2010 | 04:33 PM
A flashing check engine light means a misfire. Check your codes and see which cylinder is misfiring. Chances are that your coilpacks could be on their way out. There was a recall on 2001 and up coil packs. Give your local Audi dealership a call so they can run your vin and find out if your qualify for the recall. It sounds like a coil pack issue though. It could also possibly be a maf issue but the coil pack problem is a lot more common with our cars.
Old Aug 3, 2010 | 05:07 PM
MiamiA4guy's Avatar
I have the same problem i took it back to the dealer and they told me that they only took one out and replaced one -___- so two day's later the same thing happened but not as bad so i went out and purchased some new spark plug's and it improved alot but from time to time it does a violent shutter lol in the morning's only when it's cold but now im saving up to buy a new pack of coil's and taking it slow
Old Aug 3, 2010 | 07:59 PM
5Speedwtneed's Avatar
I had this problem. replaced the coil packs and it didnt help. Replaced the MAFS and bam, all fixed lol.
Old Aug 3, 2010 | 11:36 PM
Plugs could be an issue too...they will gap themselves after a certain period of time so it doesn't hurt to check them from time to time. That's weird that they wouldn't replace all the packs considering the recall.
Old Aug 3, 2010 | 11:45 PM
jfact7
Sep 2, 2011 06:33 PM
kaklexicon
Jun 16, 2008 06:09 PM
Wintermute
Mar 14, 2007 10:35 PM
NeverComingBack
Mar 24, 2006 03:12 AM
