Puncture in the oilpan...
Old Dec 5, 2008 | 11:59 AM
barrylott's Avatar
Default Puncture in the oilpan...
I should have never loaned my Audi....
Girlfriend hit something in the road, and it resulted in a punctured oil pan. Luckily she stopped before there was any damage.
My questions, can the oil pan be welded, and what are the pros and cons
How big of a job is it to remove the oil pan
1999 A4 Quattro, 2.8L
Thanks!
Old Dec 5, 2008 | 12:17 PM
hiwords's Avatar
it's easy to take off the oil pan. just lift up the front end and take out all the bolts you see on the pan. then, you gotta find yourself a respectable welder who can weld aluminum. is the whole huge? if so, you should just save yourself the trouble and get a new one. junkyards should have them. there are no drawbacks if the welding is done right. hope you learned your lesson on loaning cars to a female lol. good luck
Old Dec 5, 2008 | 12:54 PM
barrylott's Avatar
Thanks. Can you define "lift up the front end"? Are you saying the engine has to be partially pulled?
It is a pretty good size hole, and yes, lesson learned!
Old Dec 5, 2008 | 12:59 PM
hiwords's Avatar
o sry, i meant just jack up the car. if the hole is larger than a nickel forget it and just get a new one
Old Dec 5, 2008 | 05:49 PM
Tweaked's Avatar
Thanks!
It's kind of a btch to do as the subframe gets in the way, but it is certainly possible to do on your back. Replace the pan, don't cheap out and risk poor welds or having your car down forever waiting to get the pan back. Consider replacing the bolts as well.
And we all know you did it... stop blaming your girl!
Old Dec 5, 2008 | 06:18 PM
compmanben's Avatar
^agreed
Old Dec 5, 2008 | 08:17 PM
SAudi's Avatar
hes a 2.8 driver, we dont have the subframe issues, he just need to loosen and move the sway bar out of the way to get to some of the bolts. also make sure you get new bolts their strech type and will snap on you if you overtighten. also not sure on teh 30v but if the gaskets messed up and you need to put in a new one (chances are you will) youll also have to take off the oil pick up tube to get the gasket out.
Old Dec 6, 2008 | 02:33 PM
flyromeo3's Avatar
I actually changed mine not to long ago. I also have a 2.8 30v
IF you dont have access to a lift, just jack up the car and put jack stands on either side.
You have to unscrew the sway bar cause its blocking the back part of the bolts on the oil pan.
Remove just the 4 bolts holding up the bar, the endlinks can stay on but you'll have to slightly flex the bar down to gain access to those bolts. IF you have a flexible 3/8 socket adapter it'll help.
I believe it was 18 or 19 bolts alllllllllll around the pan.
Take them off and the pan will only need a tap to come off.
Clean up around the mounting points and remove any silicone that may still be there from before.
If you can get to an Audi dealership/ parts buy some of their high temperature silicone. I think RTV is good to use also.
Put some around the oil pan and begin to screw the bolts back in. Dont screw them in too much. You want the silicone to dry for a couple minutes. Then continue tightening the bolts in a criss cross pattern.
I would just replace the oil pan. If the hole isnt that big buy some metal epoxy stuff and seal it up. Worked with me when i cracked my pan the first time.
I've heard off people welding their oil pans too.
I ordered mine from these guys
http://cgi.ebay.com/ebaymotors/Audi-...Q5fAccessories
Email them first so they can get you the correct one.
Old Dec 7, 2008 | 09:15 PM
Tweaked's Avatar
Boo. Don't do that. It's not worth risking an oil-out.
mypreludeisred
Oct 17, 2006 02:58 PM
lan_van
Nov 3, 2005 04:15 AM
