Put in aftermarket amp
Old Feb 9, 2010 | 12:59 PM
Nightstalker14's Avatar
Default Put in aftermarket amp
i have an 2001 audi a4 with symphony system and im trying to put in an amp for the rear speaks but i dont know where to solder the rca`s for the amp. to get a signal for the amp. a wiring diagram would help.
Old Feb 9, 2010 | 01:15 PM
Hdale85's Avatar
Why for the rear speakers?
Old Feb 9, 2010 | 01:18 PM
Andrew149's Avatar
i have a 1200watt for all my speakers =] im running 10 speakers
Old Feb 9, 2010 | 01:36 PM
209AudiGuy's Avatar
are you still using the factory head unit? if so your going to need to solder both the rear speaker wires behind the head unit, unless you can find the wires before they go into the factory amp. i had to do this in my a4. i can take some pics later if you would like
Old Feb 9, 2010 | 01:44 PM
Andrew149's Avatar
no all my factory wires are taken out and i put in all new wires and installed a pioneer deck
Old Feb 9, 2010 | 01:46 PM
209AudiGuy's Avatar
talking to nightstalker. but putting in an aftermarket deck makes it easy cuz your rca outputs are on the back of the af headunit
Old Feb 9, 2010 | 01:48 PM
Andrew149's Avatar
yep pretty easy
Old Feb 9, 2010 | 03:25 PM
hiwords's Avatar
aren't the deck speakers already amped with the stock one?
here's the diy for adding a second amp to the stock one
http://www.a4mods.com/index.php?page...tml&category=4
Old Feb 9, 2010 | 03:50 PM
Andrew149's Avatar
i like that website but its for b6's =[
Old Feb 10, 2010 | 08:30 AM
i got the power ground and remote hooked up i used the old amp connecter i just need to know which wires to hook up the RCA from the connector.
