Put it some HIDs, no more instrument cluster.
OK, to start out with I have searched this one and not come up with anything definitive.
I have a 98.5 A4TQM. Yesterday I put in Valeo One-piece HID housings with a VVME D2S kit. The lights work great, look great, etc.
The problem I have is now my instrument cluster doesn't work. I still have ambient temperature and voltmeter, but nothing else. No tach, speedo, coolant, clock, etc. I already went through the fuses, and none of them were blown. If these two were tied together for power, they should both not be functioning, but the headligths still function perfectly.
Also, the CEL has come on, which could be unrelated, I have to run VAGCOM to find out for certain.
If anyone has any insight, I would be most appreciative.
I used ECS wiring adapters to wire from stock harnesses, and I did already check all the fuses.
), none of the needles work except the voltmeter
have you tried disconnecting your lights and turning your car on to see if your instrument cluster comes back on? that would be a sure way to figure out if this problem is directly related to your recent install. just throwin it out there...
No man is perfect. You cannot be a Mac daddy, liked by people all over the world. So it is with war power leveling. Although it can provide express fun experience of high level, not all the MMORPG players use Warhammer power leveling. Since warhammer online gongce, more and more MMORPG players joined this game. At the same time, a few of them chose Warhammer online power leveling so that they can find happiness of high level while do not have to level their characters hour after hour. They may buy 12 hours War Power leveling, 24 hours Warhammer leveling, or 1-10/10-20/20-30 warhammer leveling packages as they like.I just know more friends need wow cd key now and item4u.com can serve you. World of Warcraft cd key prices are usually different from store to store and different from server to server. Perhaps item4u price is not the most bottoms, but the service is certainly the best. To buy it or not? If yes, do not miss item4u.com.
